Motherboards Asus sabertooth settings....
Discussion in 'Hardware' started by Harlequin, 4 Jan 2014.
  1. Harlequin
    Harlequin Modder
    4 Jun 2004
    anyone got some good optimized asus sabertooth settings? mine seems a little flaky around the ram (corsair xms3 1600 cl9) had to reset it a few times :(
  2. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Load optimised defaults. Do not volt the ram, leave it alone. I'm not sure about the Saber, but if it's anything like mine (and it should be) then my settings in this thread should help you.
    http://forums.bit-tech.net/showthread.php?t=265008
    Run a memory test and make sure your memory is OK.
  3. Harlequin
    Harlequin Modder
    4 Jun 2004
    hmmm been running with spread spectrum on , gonna turn it off and run - gonna set max turbo to 5ghz and have a play; before aiming for 5ghz standard :D
