Hardware Asus Sabertooth X79 Review
Discussion in 'Article Discussion' started by arcticstoat, 30 Nov 2011.
  1. trig
    trig god's little mistake
    10 Aug 2006
    no doubt, but dont forget, this is an enthusiast site...we don't need tri-gtx 580 sli and 16+ gb ram...or 6-core 12 thread cpu's...but we want it...i can get 40 + fps with a core 2 duo e8400 and a gtx 275 on most games out there...but by god if i get an extra $100 in my pocket i'm sellin that gtx 275 for a gtx 560ti...
    if i had $2000 to drop on a new rig and i wasn't so psyched about the power savings benefits of IB, i would be on this bus...and all i do is surf, do some work from home, and occasionally bust out a night of r6 vegas 2 or l4d2 or something...
  2. Pookeyhead
    30 Jan 2004
    "Intel Core i7-3960X (32nm, 12MB Level 3 Cache"
    You mean 15MB surely?
  3. Combatus
    16 Feb 2009
    No you don't have to be, but all our LGA2011 coverage points to the fact that LGA2011 is aimed at/best suited to professional users that regularly make use of n-threaded applications. Otherwise it's just not worth it over a high-end LGA1155 system. If, based on this fact you are in the market for an LGA2011 system, the Sabertooth X79 is good value compared to other X79 boards we've looked at recently, including some that are significantly cheaper, which we'll cover in the near future. If you're in the market just to have the latest hardware, well, we doubt most people in this situation take much notice of scores anyway!
  4. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    The purpose of this board isn't to toss together a MW3 gaming rig. It's for exactly what the review says: professional multithreaded applications. LGA2011 and corresponding X79 systems are not meant to be poking around playing console ports just as cheapo AM3 systems are not meant to be tackling heavy video editing/photoshop/3D modelling/et cetera.
    Where are the gun designs? The VRM heatsink/shroud is just a black plastic box and the southbridge shroud is just black plastic with some lines in it.
    You must be thinking of this. Now there's a ridiculous board. Even more expensive than the Sabertooth X79 and purposefully aimed at gaming.
  5. BlackMage23
    BlackMage23 RPG Loving Freak
    4 Aug 2006
    Can someone please tell me why high end boards still have a PS2 port on them?
    I know I have not used PS2 in years, and I don't think anyone buying this board will be.
  6. trig
    10 Aug 2006
    true...
    and if i am completely off, then i'm off...but reviews in the past have been fairly middle of the road in regards to usage (again, meaning the products were scored for general usage) with added commentary that if you are this user or that, then this might be etc etc...and maybe that's what it comes down to, that this platform cost is so over the top that the general usage is professional multi-threaded app user...in which case, i somewhat get it, but you still don't really justify the price of the board over, say, the as-rock...at least not in my opinion or at least not in this particular review...50% more money on a $200+ mobo, for middle of the road performance vs other x79 boards, because you can control fan speeds better?
  7. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Lol, I guess you haven't listened to this weeks podcast then? ;)
  8. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    As I may have said here previously, SB-E seems to be an e-peen extender in this market. IF you are someone running serious, actual mult-threaded programs, then yes, SB-E is for you. However, if you want to squeeze 5fps more out of Skyrim or whatever and therefore you're going to drop SB-E kind of money on it, just admit it: it's the nerd equivalent of the balding, middle-aged middle-manager with a bimbo girlfriend and a Porsche.
    Or maybe I'm just bitter because Bulldozer would be a skanky girlfriend and a Porsche with rust damage and a dead cylinder :D
  9. Guest-16
    Guest-16 Guest
    It's not a gun magazine, it's just a heatsink :confused::confused:
    The Sabertooth has nothing to do with a military motif, apart from the Military Grade components which are used to describe the fact the same components are used in military spec hardware that requires flawless operation, not "OMG GUNZ PEW PEWPEW"
  10. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    link to the ASRock X79 Extreme 4-M review or is that still being worked on?
  11. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    You still do not get the point. You do not need this over expensive gimmicky motherboard to do all your multitasking heavy video editing, lightwave or what ever stuff you think will be slow on less expensive motherboards. If the benchmarks shown right here in this review shows the numbers are so close together that it is impossible to notice compared to other and much cheaper boards.
    Put the cheapest motherboard with cheapest memory and most expensive motherboard with expensive memory with same processor and videocard and do a blind non benchmark test with photoshop or whatever application where you do not see bench results and numbers. I BET that you do not notice any difference at all.
  12. Combatus
    16 Feb 2009
    ASRock has made some pretty good boards - and I agree on speed alone there isn't a lot between them. However the Sabertooth has a far better EFI, is easier to overclock, has other very useful features such as USB BIOS Flashback (useful if Ivy Bridge E requires a BIOS update too) and the Thermal Radar utility is easily as good (if not better) than a £50 programmable fan controller. It's also got better cooling as standard and you're far more likely to be able to buy third party waterblocks for it. At face-value it probably doesn't seem like a lot, but when you start making a list, like we did, the Sabertooth is far more desirable and definitely worth the extra £50-60 over say the ASRock Extreme4. As I mentioned, we'll be posting reviews of plenty of other X79 boards over the coming weeks so watch this space then decide for yourself ;)
  13. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    I don't think people get it. The price and positioning of the Extreme processors is such that the 8-core dual-socket processors won't look quite so badly priced :)
  14. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Did you say that it's used by people with mechanical keyboards? Haven't listened to the podcast, but that is a reason for it. Allows for "N-key rollover" a.k.a. you can press any number of keys at once and they'll all be input.
    Any X79 board is going to be expensive, you're only saving around $100 by grabbing one of the other boards tested in the review. Bit even say in the review that the extra price is not warranted by extra performance, it's worth it for the extra features which they found to be legitimately useful.
    This post recaps what the article says about the usefulness of the features:
  15. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Yes indeed, that was the reason.
  16. trig
    10 Aug 2006
    well, i think what it boils down to is perception of general use of this board from me is that the user will be a heavily multi-threaded app user...the article was written under the assumption that the general usage will be heavily-multi-threaded app,super over-clocking, massive bios re-jiggering, need ultimate cooling performance user...
    to put it in another perspective..p35 boards...there were boards that oc'ed pretty well, but they were pricey...then came the abit ip35 pro...suddenly you had a board that could oc with the best, had good cooling, and didn't cost an arm and a leg...you guys gave that a 7/10 on value...that would be the equivalent of a 17.5 out of 25 score today...this x79 board got a 21...it has the bonus features, but i just can't see the 21 score...
  17. Pookeyhead
    30 Jan 2004
    Slightly disappointed the Asus P9X79 Pro wasn't in that line up.
  18. dicobalt
    dicobalt What's a Dremel?
    21 Mar 2009
    I'm happy with my Sabertooth P67. I don't see much of a reason to bother with socket 2011 unless you need more than 16GB of ram for virtualization or databases.
  19. seismic2k
    seismic2k What's a Dremel?
    12 Dec 2011
    Looking for a new motherboard for a new pc and will probably be overclocking it, i really like all the thermal sensors so i know when its cooking before the smell hits me. One of the biggest draws for me though is the double spacing between the PCI-E x16 slots, i don't like the idea of having 2 hot graphics cards too close to each other
Tags: Add Tags
