Hardware Asus Striker II Formula
Discussion in 'Article Discussion' started by Tim S, 25 Jan 2008.
  1. ryanjleng
    ryanjleng ...
    15 Nov 2007
    A really nice read. thanks.
    now, only if they can make it cooler.
  2. Nature
    Nature Member
    21 Nov 2005
    Does it support a native 1600 fsb>>?
  3. rt182
    rt182 New Member
    26 Jan 2008
    hmmm there is no LCD post listed in the box contents does this mean they have tossed it???? in the other reviews of this board it states there is a LCD poster included and on the ASUS website
  4. Wwhat
    Wwhat Member
    2 Oct 2005
    You know my old asus nforce2 motherboard also had the temperature probe connector, seems weird how they hang on to that so long without supplying a probe, or even instructions as to how to make your own.
    I also have a q., I hear intel chipset boards often have a very high precision timer chip, do any nvidia chipset board have that?
    @rt182 look at the left out pictures in the comment above, there you'll see the LCD
  5. Trinityfitness
    Trinityfitness Trinityfitness
    27 Jan 2008
    You said That you can't use water cooling with the Striker II
    Why is that ?
    I am thinking of getting this MOBO
  6. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    unlike some of the recent motherboards, it doesnt come pre-fitted with a northbridge waterblock, doesnt stop you from buying one thou, at the expense of the heatpipes
  7. rt182
    rt182 New Member
    26 Jan 2008
    Man can this hurry board hurry up and get to AUS i want it now
  8. Guest-16
    Guest-16 Guest
    Welcome! You can use watercooling on the CPU - but you have to use the heatpipe fans provided to provide airflow to the fins. There's no specific northbridge watercooling version like previous RoG boards though. :)
  9. Krikkit
    21 Jan 2003
    A lovely review, but I'm still using a PS/2 mouse! This MX1000 has problems over USB, and the only solution is to use it over PS/2. :p
  10. Trinityfitness
    27 Jan 2008
    I am building a new pc.
    Can any one tell me what RAM will work with the STRIKER II Formula in dual chan...
    I would like to get something fast maybe 1066 or better like 12000
    but don't want to have it not work like alot of other people
    any sugestions?
  11. Guest-16
    Guest-16 Guest
    Kingston PC2-9600 - fantastically fast and cheap memory. We used it in the review.
  12. Guest-23315
    Guest-23315 Guest
    Unless you were to fork out over £100 for a full set of chipset and Mosfet waterblocks! :thumb:
  13. Guest-16
    Guest-16 Guest
    Well, yes :p but you'd need northbridge, 2x mosphet, southbridge and NF200, plus make sure they all fit with the holes :eeek:
  14. Trinityfitness
    27 Jan 2008
    I was thinking of 4 gig kit that would only take up 2 slots
    do you know if the OCZ DDR2 PC2-8000 1000 MHz 4GB(2x2048MB) Platinum Edition Dual Channel Kit Would work well with The Striker II Formula
    or would ( 2 kits of 2 - 1GB) kingston 9600 DDR2 1200Mhz Non-ECC CL5 from Work better? I am worried about OCZ compatibility With the Striker II
    My build so far
    Striker II Formula
    Core 2 E6850 3.0 Ghz
    BFG 8800 GTX OC2
    Raptor 150 gig
    Ultra X3 1000watt PS
    Gigabyte 3D Mercury Case W/ BUILT-IN Liquid Cooling System
    Ram??????
  15. FrozenAsset
    FrozenAsset Want to see my Glock?
    5 Feb 2008
    Just bought this board along with an E8400.
    Upgrading from a DFI NF4 Ultra-D w/ 3800+ X2.
    The manual states "While in DDR2 1066 mode, ASUS's exclusive technology offers a choice of FSB 1333, providing..."
    Do I have to have DDR2 1066 RAM in order to hit 1333 FSB?
    I have 4GB (2x2GB), of Patriot Viper RAM coming with the board. PVS24G6400LLK
  16. DAWG1971
    DAWG1971 New Member
    28 Mar 2008
    I have recently purchased the Asus Striker Formula MOBO. Any suggestions on the best and stable memory for this beast? Anyone have any luck using the Kingston PC2-9600 memory?
Tags: Add Tags
