Hardware ASUS Strix GeForce GTX 980 DirectCU II OC Review
Discussion in 'Article Discussion' started by Dogbert666, 8 Oct 2014.
  1. Dogbert666
    Dogbert666 *Fewer Staff Administrator
    17 Jan 2010
  2. rollo
    rollo Modder
    16 May 2008
    If you must have a single gpu solution then the 980 is the card to buy. For most though they will take there chances with SLI and buy 2 970s for very similar money and 50-80% more performance depending on title.
  3. Troglodyte
    Troglodyte What's a Dremel?
    29 Mar 2011
    Agreed ; think we need the guys to do a 970 sli vs R9 295x2
  4. Harlequin
    Harlequin Modder
    4 Jun 2004
    £660 gets a 295X2 vs £500 for 1 GTX 970
    good game that as the 295X2 beats the 970SLI @4k for far less money
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    970 is £260 - 300, 980 is £425 - 500.
    Which makes 2x 970 almost £100 less than R9 295x2
    However the 290x has been dropping in price recently and can be had for pretty much the same price now as the 970, so it should be 2x 970 vs 2x R9 290x due to the very similar price.
  6. Harlequin
    Harlequin Modder
    4 Jun 2004
    oops was reading the review 980 when comparing prices .... ofc its all a `game` as NVidia had to play catch up when amd brought the 990 out etc .
  7. jon
    jon Chief Phrenologist
    26 Aug 2009
    I had to check the thermals on the R9 295x2 to make sure I wasn't seeing something drastically wrong in your report ... but as your review of that beast states, your thermals are based on the liquid temps in the watercooler, not the cpu itself.
    Still, think about the fact that the R9 295x2 draws 300w more under load ... that's a lot of heat (being handled nicely by the cooler) but also a lot more power draw.
Tags: Add Tags
