News Asus to launch mATX Republic of Gamers Gene mobos
Discussion in 'Article Discussion' started by Tim S, 10 Feb 2009.
  1. tominated
    tominated What's a Dremel?
    28 May 2008
    2 words:
    DO WANT
  2. icutebluezone
    icutebluezone The meaning of life is to MOD
    6 Aug 2007
    1 word. SWEEEEEEET.
    Was waiting for sum one do do one. after seeing DFI mtx boards.
  3. Lazarus Dark
    Lazarus Dark Minimodder
    14 Apr 2006
    Finally. I have a Maximus Formula board with a Q6600. I'll OC on occasion, but not all the time, I don't buy into the whole SLI/Crossfire thing, so I only have one GFX card. And I use one PCIE tuner card. The other 4 or 5 PCI/PCIE slots are a waste of space. I plan to get a raid card but that will still only be 3 slots filled. I've been looking at upgrading to I7, and I may have found my motherboard. Plus I can fit it into the Lian-Li PC-V350B, a mATX case that fits full size PSU's and plenty of room, not to mention it's gorgeous. (I just built my mom a pc using the S version of the case, it really is a fantastic case) Viva la mATX.
    Still, why the freaking legacy? PCI, IDE, and I bet that's a ps2 port. Why won't legacy die already?
  4. Scirocco
    Scirocco Boobs, I have them, you lose.
    3 Jul 2007
    I'm excited another company is releasing an enthusiast/gamer m-atx motherboard. I was eyeing the DFI Core i7 m-atx board, but the UV slots, etc. just do not fit with what I like to do. This at least gives an alternative to choose from. With any luck other companies will take note and do the same.
  5. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Does anybody know if there is a AM3 republic motherboard coming? And where are the BT reviews of the new AM3 motherboards and AM3 PhenomII processors? You guys are really late, while the rest of the competition (other hardware sites) have their benches out already.
  6. naokaji
    naokaji whatever
    8 Dec 2006
    How many % of those who can afford I7 + x58 board + DDR3 still have ide drives though they actually use? I'm certain it's not even 5%.
    They have so many different sku's allready it woudn't matter if only some of them had the old connectors like ide, pci, ps2...
  7. Xir
    Xir Modder
    26 Apr 2006
    While I usually don't overclock, having more choice for the mATX market is great.
    Still using IDE DVD drive...why not? No change necessary.
    Additional backwards compatibility won't harm you :)
  8. Nikumba
    Nikumba Minimodder
    29 Aug 2001
    Space is limited, so people could be using a laptop CD drive in a small case, which would require an IDE port.
    I also have a top end Pinoeer DVD wrtier on IDE, and since the burner cant saturate the IDE channel, there is no point in spending the money on a SATA one
    Kimbie
  9. Vimesey
    Vimesey What's a Dremel?
    21 Jun 2008
    You can get laptop size drives that use SATA, and SATA drives are just as cheap these days.
    I agree on such high end hardware, legacy does not need to be supported.
  10. xrobau
    xrobau What's a Dremel?
    12 Feb 2009
    The thing you HAVEN'T done is count the SATA interfaces. Go on. When you get stuck after '1', then you'll realise why 8)
    --Rob
  11. zoom314
    zoom314 Minimodder
    10 Jun 2003
    Yes You did, I put the photo into Paint Shop Pro 4.12 and brightened the picture up some and sure enough, there are two sets of holes around the cpu socket. As to the so called weakening, the backplate will eliminate that, So It's a non issue. :thumb:
  12. tombmx
    tombmx What's a Dremel?
    13 Feb 2009
    I counted 7 lol. were you go to school..?
    ps2 is the only one i see that ill need as sometime during overclcoks a bad bios = no usb so no keyboard :(
  13. icutebluezone
    6 Aug 2007
  14. [USRF]Obiwan
    9 Apr 2003
    JFC! That thing is huge, and I will bet that it ain't keeping it cooler then a TRUE120. Does it even fit in a case?
  15. icutebluezone
    6 Aug 2007
    Wouldnt fit my case. :) Dont really like the look of that cooler anyways. The mobo on the other hand would fit my case. :D
    What I want to see is the board with 2 gpus installed and a nice cooler on it.
  16. tominated
    28 May 2008
    i would sooooo be sticking that on my case. It's fricken epic man!
  17. icutebluezone
    6 Aug 2007
    Any more news on this board?
  18. tominated
    28 May 2008
    it's on sale in oz.
  19. icutebluezone
    6 Aug 2007
    arrrrrr dam you oz. lol. give it another 3 or more weeks and maybe it be in NZ only if http://www.computerlounge.co.nz/ import it like thay did with the DFI LANPARTY JR X58-T3H6 LGA1366
  20. Asulc
    Asulc Minimodder
    18 Jul 2007
    Will Bit-Tech be doing a review on this board?
Tags: Add Tags
