Hardware Asus Triton 85
Discussion in 'Article Discussion' started by Guest-16, 26 Jul 2008.
  1. Guest-16
    Guest-16 Guest
    http://www.bit-tech.net/hardware/2008/07/26/asus-triton-85/1
    Everyone wants the same things from a new heatsink; silent operation and high thermal performance, but the combination of both is notoriously hard to strike. We take a look at the Asus Triton 85, which claims to run at just 16 dBa, and find out if it can deliver the goods.
    :waah:
  2. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    Looks like the Thermalright 120 eXtreme still has the best balence (depends what fan you buy obviously), it's been top of the pack for quite some time now!
  3. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    isnt that worse than the intel stock cooler? and thats free lol
  4. Guest-16
    Guest-16 Guest
    we'll be including a stock intel HSF in our results tables soon, so you'll be able to tell.
  5. Matticus
    Matticus ...
    23 Feb 2008
    So its a complete waste of money. Shame, I have really started to like the look and idea of top down coolers for some reason and it looks like only Noctua make one that is worth going for.
    Also you wrote Akasa 465 in the conclusion and the graphs, don't you mean 965?
  6. ParaHelix.org
    ParaHelix.org What's a Dremel?
    19 Jun 2008
    I wouldn't buy this heat sink particularly, but it would be nice to have it thrown in with the Asus motherboards for those who aren't overclocking and such.
  7. Jipa
    5 Feb 2004
    They still fail miserably in making coolers. Stop it already, it's like license games, they quite silmply always suck.
  8. azrael-
    azrael- I'm special...
    18 May 2008
    IMHO top-down coolers are a good thing! Just a shame there aren't so many good ones out there. Sure, tower coolers have better cooling ability, but they don't cool the PWM area of the motherboard, which is exactly where top-down coolers trump tower coolers.
    OK, so this cooler might not be the best thing since sliced bread, but I cannot question ASUS' design decision on that point. They might want to sell it (a lot) cheaper though.
    Incidentally, doesn't the Triton 85 look a lot like the Triton 75 (which is sold fanless)?
  9. CowBlazed
    CowBlazed What's a Dremel?
    9 Dec 2005
    If you include stock Intel coolers, maybe use a few different ones or at the very least mention from which CPU line the stock is from, lots of changes in the last few CPUs, such as the 45nm stock coolers.
  10. Amon
    Amon inch-perfect
    1 Jun 2007
    That's a high ambient temperature.
  11. salesman
    salesman What's a Dremel?
    29 Apr 2007
    Sweet because that's what i use so it'll will give me a better perspective when i decide if I want to get an aftermarket cooler.
  12. salesman
    29 Apr 2007
    "it'll will" say it ten times fast an a Thermalright 120 eXtreme it'll will pop out your butt.
  13. Baz
    Baz I work for Corsair
    13 Jan 2005
    It's been hot in the office this week.
  14. Amon
    Amon inch-perfect
    1 Jun 2007
    Air-con buggered or has it been one of those scorchers this week?
    That's a miserably flawed argument. Apply the same logic to any other industry (AMD, ATi, or Ford Motors) and you'll soon realize the repercussions consumers incur in a weighted market.
  15. Baz
    13 Jan 2005
    Air con? We're in th UK - Air conditioning consists of opening a window or desk fan if you're lucky!
  16. kenco_uk
    28 Nov 2003
    Opening a window? So they're not nailed shut?
  17. roadrun777
    roadrun777 What's a Dremel?
    30 Jul 2008
    Again, bit-tech, no noise rating? no db rating? no audio files of fan noise at different distances?
    If all people cared about was cooling ability, then this type of review would be great, but as you pointed out, it's all about how silent it is and how well it performs.
  18. Baz
    13 Jan 2005
    Weight (with fan): 520g
    Size (with fan): 120mm(W) x 137mm(D) x 123mm(H)
    Fan Size: 120mm
    Fan Speed: 1400RPM
    Noise Level: 16 dBa
    Warranty: Two year standard warranty
    The fact of the matter is that noise rating hardware is enormously difficult, and completely subjective dependant on situation. All we can do is compare a silent fan to a silent fan, as we lack the high end setup to reliably test the fan. We'd need a sound insulated sound room, which just isn't on the cards.
  19. itsasony
    itsasony What's a Dremel?
    6 Mar 2009
    Then there's the whole <b>Socket F</b> thing. Everywhere around the web I shopped this cooler it was advertised to support Socket F. We can tell you it doesn't support the bolt through Socket F with the supplied clips. When I contacted the manufacturer about getting clips that would make their cooler work with socket f, I was told to contact the reseller, that the manufacturer doesn't offer parts. This doesn't tickle. SO if you buy one of these for socket F, you might get F'd and it wont be cool.
Tags: Add Tags
