Hardware Asus Vulcan ANC Review
Discussion in 'Article Discussion' started by Claave, 27 Aug 2011.
  1. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    A good gaming headset, maybe. I think the best part it the (what looks like) removable/replaceable cables in this price range. Go Asus :D
  2. GiantKiwi
    GiantKiwi What's a Dremel?
    6 Jan 2011
    removable audio cable to prevent ear wrenching on snags? how about most of the Steelseries Headsets which implement it like that as well....?
  3. D3Mamba
    D3Mamba What's a Dremel?
    28 Aug 2011
    Could somebody tell me if they think that these will be better than a pair of logitech G930s?
  4. Senilex
    Senilex Not a Troll. Honest.
    11 Dec 2009
    Many thanks. I hate USB headsets!
  5. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    They tell you that it's a feature, they don't force you to buy it. Why are you so unbelievably sour and mad?
  6. Elton
    23 Jan 2009
    For me though, I would still prefer just getting a seperate mic and headphone. Mics aren't too expensive anyhow.
  7. slothy89
    slothy89 MicroModder
    17 Feb 2011
    My plantronics work fine for my liking. And before you say they're not as good as <insert audiophile brand>, I don't care.. They cost me AU$60, and they're good enough to notice an improvement with dedicated audio over integrated.
    If I want massive audio I'll use my floor speakers and amp/eq. No point trying to annoy the neighbours with a headset :p
    This ASUS set looks a good alternative to plantronics if I were buying now however.
  8. D3Mamba
    28 Aug 2011
    Does anybody know if these support surround sound?
    Also would the ASUS be better then a pair of logitech G930s?
  9. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    anyone know a date on this?
  10. D3Mamba
    28 Aug 2011
    can someone please tell me if the ASUS supports surround sound?
    also will this be better than a pair of logitech G930s?
  11. 2bdetermine
    2bdetermine What's a Dremel?
    2 Apr 2009
    Just wait for Razer Tiamat 7.1.
  12. Vo0Ds
    Vo0Ds Fake potato
    6 Feb 2004
    Don't think I could go Asus for headphones, though some nice features for the price.
  13. Otis1337
    28 Nov 2007
    now in stock at scan, just orded mine! :D
  14. Baz
    Baz I work for Corsair
    13 Jan 2005
    The Vulcan is a stereo headset - so no 5.1 or 7.1 emulation. Haven't tried the G930s.
  15. Nums
    Nums What's a Dremel?
    10 Feb 2012
    Poor mic and pointless ANC
    Thought that I would share my experience after buying the Asus Vulcan ANCs:
    I recently purchased this headset (and it's now on eBay) as the mic is the worst that I have come across as you cannot position it close to your mouth, forcing you to have to turn up all the sensitivity settings, thus transmitting all your background noise to your fellow gamers as hiss. Unsurprisingly this makes you somewhat unpopular...
    The ANC function IS pointless if you wish to listen to the output from the headset's drivers (I assume you do!) as the ANC cancels out a lot of the lower frequencies. If you wish to sit on an airplane and cancel out the noise of the engines then I'm sure they work beautifully. Maybe I should be playing BF3 on a plane!?
    So a headset that has poor mic positioning, a pointless ANC function, no software (to allow you to modify the sound should you wish to) and doesn't even come with a battery for £90!?
    They are beautifully built though...
    I agree with GiantKiwi's thoughts (and I have used them!)!
  16. pistol_pete12
    pistol_pete12 What's a Dremel?
    15 Nov 2011
    Consider this.....
    Why would someone require a gaming headset with ANC?
    Maybe because that person lives in a noisy area, has a noisy PC or wishes to receive better signal-to-noise whilst at LAN etc.
    And what sounds would a person be missing whilst playing in a noisy environment?
    A few examples - Calls from team members, footsteps, gunshots from behind or in the distance, the bounce of a grenade etc.
    Most of these sounds are discreet and require more mid-high-frequency emphasis to become more audible. I purchased an Audio-technica AD700 headset for this very reason which is incredible in a quiet environment. Unfortunately in a noisy environment, due to its open design, the sound quality is significantly affected.
    SO, the Asus Vulcan - Yes, the ANC function will reduce low-frequency sounds so you won't experience punchy explosions and perhaps a more immersive atmosphere, however, it DOES significantly reduce background ambient noise and therefore DOES enable you to hear the more important sound cues in a game.
    A team mate of mine had this headset at i46 whereas I was using the Plantronics Gamecom 377. First impression of the Vulcan was it looked good and was very comfortable. When I used it in-game however, I was completely bowled over by the amount of reduction in background noise with the ANC turned on. As you press the button it's almost as though you are stepping into a sound-treated room. This was hugely beneficial as we were playing CSS which requires very acute hearing. I was able to localise footsteps, gunshots etc much easier. I noticed that as soon as I switched back to the Plantronics headset I had to wack up the volume to an uncomfortable level so as to drown out the background noise!
    I guess for a game such as BF3 however, where part of the enjoyment is the incredible atmosphere made by explosions, vehicle noise etc. and where there is less emphasis on more discreet sounds, this technology would not be so important. Like most peripherals, it's very much a personal decision.
    The only disadvantage in my opinion is the mic - as said by others, the users' voice can sound quiet/distant and almost mechanical. With some tweaks this can be improved.
    I will certainly be purschasing this headset prior to my next LAN :)
Tags: Add Tags
