Other Asus Vulcan microphone, strange humming in background.
Discussion in 'Hardware' started by David164v8, 24 May 2012.
  1. David164v8
    David164v8 Minimodder
    29 Aug 2011
    Whenever I use my microphone, there is a strange humming in the background. I'm certain it's not my PC because if I cover the the mic with by hand no ambient noises can be heard, and the humming gets really loud. I'm using my new Xonar DG, and I have no idea what's doing this.
  2. lp rob1
    lp rob1 Modder
    14 Jun 2010
    Are you running the headset through the front panel audio ports? If so, the problem may lie in a ground loop. I had a ground loop problem with my Vulcan and a Xonar DX running through the front panel of an Antec 1200
  3. David164v8
    29 Aug 2011
    Nope, straight to the card. Couldn't be bothered setting up the front panel :)
