asus x99 delux-replacement will pick up current raid 1
Discussion in 'Asus UK' started by rainbowbridge, 30 Oct 2016.
  1. rainbowbridge
    rainbowbridge Well-Known Member
    26 Apr 2009
    Hello Asus.
    Raid question when swapping out for a repaired or replacement..
    For the Asus X99 Delux (excellent board recommend) I have a nicely set up RAID 1 with two small drives.
    If I put in a replacement or repaired Asus X99 Delux (system fault, inside warranty) once I get it back from the vendor. Will it automatically pick up the current RAID 1?
    In the BIOS under EZ mode, I do not see any option to save the RAID config out to a USB drive.
    So in short if you take your ASUS X99 send it for a repair or replacement, when it comes back will it automatically pick up the current Raid 1 set up (read off the drives?) If not how do I back up my raid config to hopefully import into my replacement Asus X99-Dulux.
    Thank you,
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Short answer; yes. Just set SATA ports to RAID on the replacement board and it should pick up form where it left off.
  3. TheMadDutchDude
    23 Aug 2013
    It should do, yes. I swapped from a SOC Champion to the ASRock ITX board and it recognised it as soon as I set the BIOS to RAID. All data in tact, which I was most surprised by as it is a RAID0 array after all. As long as the chipset is the same, so X99 > X99, you should be absolutely fine.
  4. rainbowbridge
    26 Apr 2009
    Thank you guys, have a nice week.
