A/V Asus Xonar DGX or D2X for with headphones?
Discussion in 'Hardware' started by kissinger, 14 Apr 2013.
  1. kissinger
    kissinger Minimodder
    6 Dec 2011
    I looking at upgrading from onboard sound and I know that the D2X is considered to be the better card, but the DGX has a headphone amp built-in, whereas the D2X doesn't.
    So would I be better off with the D2X or the DGX considering I'll mostly be using it with headphones?
  2. Tangster
    23 May 2009
    What headphones are you using?
  3. kissinger
    6 Dec 2011
    I'm using a pair of Sony MDR-V6's.
  4. Tangster
    23 May 2009
    I would be tempted to get the DGX, but the D2X should be able to drive the 63Ohm V6 to a good volume.
  5. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    The D2X is primarily built for surround systems NOT headphones.
    Given the choice go for the DGX.
  6. kissinger
    6 Dec 2011
    I'm quite surprised by that given that the DG is roughly one quarter the price of the D2X. Even if it's built with surround in mind, doesn't it have better all round tech/components/software?
  7. Tangster
    23 May 2009
    Slightly. The Burr Brown chip in the D2X is considered superior to the C-media in the DGX and DX and supports a higher sample rate. The Essence series are the upgrades to the DGX if you use headphones.
  8. kissinger
    6 Dec 2011
    Ah, the Essence cards look great but are a bit out of my price range. My only options are anything less than £50 (new or used), so as far as I can tell its pretty much a straight choice between the DGX and D2X.
