Hardware Asus Xonar HDAV 1.3 Slim Review
Discussion in 'Article Discussion' started by Sifter3000, 22 Aug 2009.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. TomH
    TomH BELTALOWDA!
    28 Nov 2002
    Neat, but quite expensive for what it is. Particularly with a PCI interface.. Fail :(
    Linux support is likely to be non-existent too.
  3. OWNED66
    OWNED66 What's a Dremel?
    2 Sep 2007
    is the Xonar HDAV1.3 Deluxe better than all of creatives sound cards ?
  4. Elton
    23 Jan 2009
    Lol Creative. The only thing they're good for is artificial "gaming" effects.
  5. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    I don't understand the point of wasting two HDMI ports to carry separate sound and video signals - HDMI was meant to carry both together, and many AV amps don't have HDMI ports to waste like that.
    Also, how do you get an optical signal out of a coax SPDIF connector?
    £100 seems a lot of money for something that is effectively an SPDIF passthrough - something which ATI's HD cards do fine already - so what's the benefit of this card?
  6. Elton
    23 Jan 2009
    Different Drivers and it's not ALC..
  7. Edvuld
    Edvuld Minimodder
    2 Aug 2005
    It's one HDMI from your craphics card to your sound card, and one from your sound card to your AV amp. Not two separate cables. That'd be retarded.
    You use a converter, or some kind of multi cable.
    SPDIF can't carry full HD sound unless it's 2.0, so it's not just an SPDIF passthrough. I think you might want to re-read the review...
  8. rickysio
    rickysio N900 | HJE900
    6 Jun 2009
    They probably couldn't fit the PCI to PCI-e converter chip on something so small. ;)
  9. rickysio
    6 Jun 2009
    In case you're scratching your head in response to my comment, all other ASUS sound cards do use a PCI - PCIe converter onchip to enable the card to use a PCI-e X1 slot instead of a PCI slot.
  10. Flibblebot
    19 Apr 2005
    Ah, that makes much more sense. I wondered why it had two HDMI ports :rolleyes:
    I misread. I though the review said that the card was HDMI 1.3 compliant, which would have meant that the card was just passing the DTS-HD/TrueHD signal for the amp to process. Because it's only 1.2 compliant, that means the card is doing the processing instead, which does make sense now.
    I'd have liked to seen some kind of test to determine the actual saving in CPU load when using this card compared to having the CPU doing the decoding.
    Reason I ask is that I'm building a cheap, low-power movie server, but it doesn't have enough grunt to play an HD movie unless it's re-encoded to a more CPU-friendly format like DIVX - so if I could offload the video processing to a GPU and the audio processing to this card, it might be enough to allow it to play HD movies in their original format.
  11. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    Wtf is HD audio?
  12. fathazza
    fathazza Freed on Probation
    20 May 2002
    essentially its lossless surround sound, in the form of dolby trueHD and dts-HD...
    The above is pretty misleading... The only point to having this soundcard is if you want to bitstream dolby or dts... (and have the ability to decode that stram on your receiver)
    edit: well, ok it would be a fairly ok buy for someone with an amp with hdmi in but without the ability to decode true hd or dts master onboard
  13. wafflesomd
    22 Oct 2005
    I refuse to call it HD audio because that term doesn't make any sense.
  14. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    okay so I didnt read the whole thing but the whole point of HDMI is Audio and Video in one easy cable SO that HDMI in plug would thta be to take video coming off of your video card and send it to the audio card to be mixed with the audio and then the video and audio is sent to the HDMI out to go to the reciever/tv?
  15. Jipa
    5 Feb 2004
    It seems like an utter load of bollocks, though I'm sure a number of purists are willing to pay the premium to get the "HD" audion through a discrete sound card. Off to the bar, brb ->
  16. Guest-16
    Guest-16 Guest
    "HD" is classed as anything over 48KHz/16bit (DVD quality).
    After that, it could be anything, but the usual suspects are 96KHz/24-bit or 192KHz/24-bit for PCs.
  17. rickysio
    6 Jun 2009
    I feel that HiDefinition (AKA HD) is overabused.
  18. Claave
    Claave You Rebel scum
    29 Nov 2008
    This is explained in the article, please read it. :)
  19. HourBeforeDawn
    26 Oct 2006
    I rather not but thanks anyways not all that interested in the card enough to read that review, that was my only curiosity question I had about it.
  20. Saivert
    Saivert Minimodder
    26 Mar 2005
    HourBeforeDawn: You would have wasted less precious time of your life if you had just read the article, instead of waiting for replies on a forum. Each to his own I guess....
    Also I don't care if I waster time writing this post. I like it. It's fulfilling for me.
    Also Asus need to quit making crap. This card belongs nowhere.
Tags: Add Tags
