Asus Z170-A Temp Warning Message?
Discussion in 'Asus UK' started by gtiboy, 13 Apr 2016.
  1. gtiboy
    gtiboy Minimodder
    25 Apr 2008
    Hi all, I recently installed a new Z170-A motherboard after my old P8Z77 went faulty. I am running Windows 7 Ultimate 64 bit.
    After the initial boot up a pop up window appears in the bottom right hand corner of the screen saying Warning! EXT_Sensor3 -300.00 Centigrade.
    What does this mean?
  2. Big Elf
    23 Apr 2009
    It means that even after all these years Asus still aren't capable of making decent, accurate temperature reporting software, probably.
  3. gtiboy
    gtiboy Minimodder
    25 Apr 2008
    Would a fresh install of windows 7 or 10 be advisable after installing a new motherboard a few generations on seeing as that would have the old chipset drivers installed in Windows 7 from my old P8Z77 Deluxe board?
    Not sure if it would clash though which is what I'm wondering.
  4. TheMadDutchDude
    23 Aug 2013
    Set the software to ignore that reading. ;)
    It is advisable to reinstall, yes. It won't solve that message though.
  5. gtiboy
    gtiboy Minimodder
    25 Apr 2008
    So a temp reading of 300.00 centigrade is not a fault with the board itself?
  6. jinq-sea
    15 Oct 2012
    That temperature is, in theory, not possible. It's below absolute zero! I'd say it's just bunkum. Ignore it :D
  7. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  8. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    The Asus software is chipset specific uninstall the z77 version completely with its uninstaller and install the matching version from the Asus website.
    Sent from my Nexus 6P using Tapatalk
