Hardware Asus Z87i-Pro Review
Discussion in 'Article Discussion' started by Meanmotion, 29 Aug 2013.
  1. Meanmotion
    Meanmotion bleh Moderator
    16 Nov 2003
  2. Platinum
    Platinum What's a Dremel?
    25 Jun 2001
    I wonder why no one has made a DTX board of late, will still fit in ITX cases but would give you a PCI-E 16x slot and a 1x slot for sound cards / nics ect, it would limit you to a single slot card but I am sure some watercooling magic could be done as well.
    If I could get one I would, I would stick in a top end watercooled card and use the 1x slot for a decent sound card.
  3. Meanmotion
    16 Nov 2003
    QFT
  4. Guest-16
    Guest-16 Guest
    DTX was DOA mate.
    It won't fit in mini-ITX cases: 203 mm by 244 mm versus 170x170mm. Might as well go mATX 244 mm × 244 mm
  5. faugusztin
    11 Aug 2008
    I think he meant mini DTX, which is ITX + 1 slot (170x203mm).
  6. Guest-16
    Guest-16 Guest
    Ah 203 mm by 170 mm.
    Basically doesn't exist. The mini-ITX ecosystem took long enough to catch on.
  7. faugusztin
    11 Aug 2008
    Well yeah, boards do not exists. Cases do - pretty much any dual slot ITX case (which is majority of them) do support mDTX boards, as technically all those ITX cases are mini DTX cases. It's only the mDTX boards which are missing.
  8. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    As long as my mATX board can take a dual slot GPU, a sound card as well as have space for another expansion slot or two for a TV card or something else, I am a happy boy.
  9. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    It looks like some of the specs at the bottom of page 1 refer to a different m/b?
  10. jinq-sea
    15 Oct 2012
    I thought that too, Ian - was just going to write a post to that effect but you got there before me...
  11. Xploitedtitan
    Xploitedtitan What's a Dremel?
    23 Sep 2009
    I noticed, through building the comp for my bro, that Hasswell motherboards seem unable to fit the NH-D14 cooler from Noctua anymore, unlike my Sabretooth 55i. In the normal direction (fans blowing horizontally), the heatpipes get too close to the first slot and the fins were covering the other slots, which prevented inserting RAM into the 3 other slots (those Corsair sticks get too high with that useless radiator on em).
    Is it typical to Asus, or is this a problem with all Hasswell motherboard designs? Asking because I would like to reuse my cooler if I upgrade. :/
  12. Combatus
    16 Feb 2009
    Hmm, brain fart moment clearly. Sorted!
  13. Asouter
    Asouter --------
    18 Jan 2012
    I have to agree about the colour, as much as I like Asus boards. There's just no nice way of saying the colour scheme is just not my cup of tea. I was sooo relieved when Asus announced the Maximus VI Impact.
  14. Glix
    Glix Left Thumb Stick in the mud.
    11 May 2010
    Similiar issue with K2 Doom. Tis okay though, stuck a single tower Xigmatek turned sideway on to the rear and it's fine on a i5 4670k.
  15. Xir
    Xir Modder
    26 Apr 2006
    Bwech, I'm starting to loose overview.
    So I've got ATX, MATX, µATX and Mini-ITX in descending order?
  16. RedFlames
    23 Apr 2009
    MATX are µATX are the same thing but yep, pretty much
    ITX [170x170mm, 1 slot]
    M-ATX [244x244mm, 4 slots]
    ATX [244x305mm, 7 slots]
  17. faugusztin
    11 Aug 2008
  18. Xir
    Xir Modder
    26 Apr 2006
    Mini-ATX (MATX) and Micro-ATX (µATX) are not the same, sorry.
    ASUS offers both for instance.
    But I see you understand my confusion
  19. Xir
    Xir Modder
    26 Apr 2006
    sorry, please delete double post
  20. RedFlames
    23 Apr 2009
    I know Mini-ATX and Micro-ATX aren't the same but uATX/µATX and m-atx in product listings typically both refer to the 244x244mm form factor.
    And for the record, when I checked the ASUS a few minutes ago EATX, ATX, Micro-ATX [µATX] and Mini-ITX were the only options listed... The german site may be different though...
    Anyway, you're right... it's bloody confusing...
Tags: Add Tags
