at what spec/age is a computer no longer worth folding on?
Discussion in 'bit-tech Folding Team' started by scr1bles, 24 Dec 2009.
  1. scr1bles
    scr1bles What's a Dremel?
    22 Dec 2009
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Anything below a P3 is a bit of a waste of money due to the power/point ratio.
    However every unit is important (he says finishing off his 16 core, 24GB server he's "testing" over Xmas)
  3. Unicorn
    25 Jul 2006
    I don't run a machine for anything less than 500PPD, that's really what it's all about. Price to run against points that you get from the rig. Basically most people consider P4 Northwoods the absolute bottom end of the spectrum, and I'm not even sure that they produce 500PPD.
    GPU wise the low end of the spectrum is an 8xxx series card, because the folding client won't run on anything lower than that.
  4. saspro
    saspro IT monkey
    23 Apr 2009
    I think I got 300ppd tops with an old 2.4GHz P4.
    My dual Athlon MP 2600's only got 250 points each with standard clients. SMP took far too long so wouldn't meet the deadline.
    If it's at home then use AMD X2's or c2d's as a minimum.
    If you're running it on a work network (with permission) then almost anything will do as every WU counts & you're not paying for the electricity.
  5. Taffy
    Taffy Folding for Margaret 17/3/2011 RIP
    23 Apr 2009
    My old 939 was doing 2000ppd until it gave up, that was just about worth the electricity :D
  6. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    I've got Athlon X2s running, the lowest I ever saw was 69PPD! But the CPU is driving two 8800GT which generate over 4000PPD each, and they don't suffer if the CPU is folding, so I figure why not?
    In the end it comes down to how much effort do you want to put into gaining a small number of points, and if you are prepared to pay for the electricity, noise and space that will be needed.
    As Unicorn says, at least the answer is easy with Nvidia cards.
  7. cdb
    cdb No comment
    25 Apr 2009
    How much electric do you expect that to use?
  8. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    Ooh, ooh, I know this one! Way too much!
  9. Unicorn
    25 Jul 2006
    I'd half expect saspro to be running it in work though, so hopefully it won't cost him anything but it'll definately be costing someone! All for a good cause though :)
  10. saspro
    saspro IT monkey
    23 Apr 2009
    Believe it or not. Less than 460 watts.
    These low voltage Xeon CPU's are brilliant.
  11. Unicorn
    25 Jul 2006
    That's impressive sas. I found a 2.8GHz S775 Celeron and an old asrock motherboard in the workshop last night, how many PPD does anyone think that might be worth? Enough to make it worthwhile running?
  12. Christopher N. Lew
    23 Apr 2009
    Any PCIe slots? - probably only worthwhile if you're feeding graphics cards.
  13. saspro
    saspro IT monkey
    23 Apr 2009
    Agreed. I've got a pile of semperons, celerons & P4's that I'm saving for GPU mules
  14. Unicorn
    25 Jul 2006
    'Faid not lads. Did some research on it and it's an old single core Celeron D 336. The board has an AGP slot but that's no use. Might do as a small file server for the workshop some day. Then again, maybe it'll end up back in that dark corner covered in dust :rolleyes:
