Case Mod - In Progress ATCS 840 - Heart of Columbia [update:241112 - Keyboard finished]
Discussion in 'Project Logs' started by thechoozen, 15 Mar 2012.
  1. dbradford32
    dbradford32 What's a Dremel?
    22 Aug 2010
    A fellow German myself, I love this mod! It is freakin' amazing! I am jealous! My modding skills are nowhere near yours! :)
  2. thechoozen
    thechoozen Minimodder
    9 May 2006
    thanks m8´s!!!
    ok, it seems like we couldn´t hide that anymore...:D
    In the last days we continued the work on it....
    First we prepared the electronics...for that we had to solder a few things on a pcb...so that the whole thing doesn´t need that much space... (but i think we´re going to overwork the pcb in the next weeks)
    With that PCB and our Arduino we´re able to control up to 4 dc motors + 4 servos...i think the next version will combine that with a few more parts to control the lights inside that case...
    Then, we prepared the Top I/O Panel for the next step...integrating all the switches which we´re going to use to control the motors & servos....
    and at least we prepared another badge...this time a bioshock infite logo....
    we started with an engraving.....
    and after that we added some paint....:D
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nice sign. :dremel:
  4. thechoozen
    9 May 2006
    thx m8!!
    It´s update time :clap:
    In the last days we continued our work on all those small details which we´re going to integrate in our mod...so we had to engrave / cut out / paint / airbrush a few small pieces...:D
    For the 2nd sidepanel on the right side (viewed from the front) we made a zeppelin badge...
    then we made a few small flags (atm we´re not sure where we´re going to place them)
    and we made a few parts which should cover the backside of the fans (their cables) which we use in the top of the case....
    and last....
    on a local flea market we found this cool thing...
    (maybe we´re going to use parts of it for our mod...)
    Livio likes this.
  5. leslie
    leslie Just me!
    19 May 2009
    Wow, that fake wood looks absolutely fantastic!
  6. Livio
    Livio What's a Dremel?
    20 Sep 2011
    I've found this build just now. That game has a very unique mood and so does this build. I really like it.
  7. Waynio
    Waynio Relaxing
    20 Aug 2009
    Loving the fine details going into this. :):dremel:
  8. thechoozen
    9 May 2006
    thanks a lot m8´s!!! :thumb:
    the last few days we were very busy with other stuff which had to be done...so we couldn´t made that much progress that we would like to see ...but better little steps then no steps...so here comes the next update....:D
    But before we start , we wanted to send a big thank you to Coolermaster & Asus for their Support!!!
    They already sent us the first parts for the system so that we could start to integrate the hardware in our concept...:thumb:
    Before we started to paint the inside of the sidepanels we wanted to attach all parts that will be used to open/close the doors, beside that we also attached a few metall stripes to prevent the sidepanel from bending in unwanted directions....
    after that we started over with the inside of the Panels....
    Beside that we also started to work on the the Top of the Case....we already removed the original Mesh Part....so we had to replace it with something else....
    so we made a quick sketch first....
    and then we had to paint it.....
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    :jawdrop: Fanflippingtastic. :clap:
  10. thechoozen
    9 May 2006
    Time for an update :thumb:
    after starting to work on the custom watercooler set for the cosmos 2 - 2in1 edition - we also wanted to make a set of coolers for this project....
    So we started with the cpu cooler....
    before we switched over to the mainboard coolers...
    like usually ...first a bit of measuring was needed....
    then we made a few plexiglas prototypes....just to see if everything fits...
    and then we could make the final versions....
    a quick test to see if there were any leaks...(no....:D)
    and then we could mount everything on the mainboard....
  11. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Handyman number one :D, great work on those waterblocks !
  12. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    awesome details!!! Damn your works always impress cheers!
  13. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Amazing work!
    I've got to try the trick with turning black anodize red-it's a lot better than trying to reanodize!
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    :jawdrop: Nice work guys :D question though, how did you mill out the risen bits in the block for the bottom layer? mill, router or dremel even?.
    I might get brave enough some day to try myself. :D
    Very nice working blocks though & continuing the artwork onto them also, you guys always do awesome modding but this one has gone up a few notches. :D:clap:
  15. skunkmunkey
    skunkmunkey Minimodder
    15 Jul 2007
    was thinking the same thing myself!
  16. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    We all are!! Spill it!! :rock:
  17. munkey
    munkey What's a Dremel?
    24 May 2012
    I'm loving all the little details.
  18. thechoozen
    9 May 2006
    thanks a lot m8´s!!!!
    they were mill out, we build us a nice cnc for tasks like that and at the moment we´re trying out what we can do with it (the first sets of coolers we build with it)
    And now, it´s time for the next update:
    In the last days we tried out if all the electronics work like they should after we integrated everything into the case....(now we only have to do some last adjustments)
    and we also started to paint the PSU and GFX Card.....
    Dk_vr and Waynio like this.
  19. Waynio
    Waynio Relaxing
    20 Aug 2009
    Thanks for the answer on the blocks :) & congrats for getting a CNC put together. :clap:
    Love what you done to the GPU & PSU & the mechanized side panels :jawdrop: it's all going to be too awesome. :D
  20. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Looking fantastic dude!
    Have to say that the work you've done on that gfx card is awesome, remands me of a luxury yacht cabin.
