Modding atensione!!!all pro modders :eyebrow:
Discussion in 'Modding' started by noobidoo, 23 Jun 2004.
  1. noobidoo
    noobidoo What's a Dremel?
    8 Jun 2004
    atensione!!!all pro modders i have a task 4 you,i need a 120mm fan witsh is as silent and effective as posible for a water cooling project off mine. :eyebrow:
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    bit harsh but, never heard of www.google.com, you could then do you own research, you Do have the internet remember? :eek:
  3. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    i dont know.. maybey if you spell better....
  4. ubernewber
    ubernewber What's a Dremel?
    23 Jan 2004
    "wather cooling" is a top secret type of cooling utilizing orange soda and a shinny penny
  5. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    the Papst range of fans is a pretty safe bet between noise and performance.
  6. mrplow
    mrplow obey the fist!!
    5 Sep 2001
  7. Mister_Tad
    27 Dec 2002
    papst 120mm fans are excellent performers, silenX 120mm fans much better (on paper) but ive not tried them out, so i woudnt be able to back them up
    i have 3 120mm papst fans in mycase though and they are very quiet at 12v and inaudible at around 8v and lower
  8. noobidoo
    8 Jun 2004
    silenX
    will you look att this:
    Features:
    Fan Swept Forward Fan Blade Design
    Smoother, Thinner Fan Blades
    Highly Efficient Hypro Bearings
    Vibration Isolation Mounts
    Specifications:
    Fan Dimensions: 120 x 120 x 25mm
    Fan Input: 12V/1.2W
    Fan Speed: 1800 RPM
    Air Flow: 58 CFM
    Noise Level: 14 dBA
    Three Pin Connector
    Four Pin Connector
    and a Papst
    Papst 4412 F/2GL
    Abmasse: 120x120x25 mm
    Leistungsaufnahme: 1.25 W
    Lagerart des Lüfters: Sintec Gleitlager
    Nenndrehzahl: 1600 /- 10% RPM
    Förderleistung : ca. 55,4 CFM
    Geräuschpegel: ca. 26 dB(A)
    Drehzahlüberwachung : nein
    Anschluss: 3-pin.
  9. Mister_Tad
    27 Dec 2002
    the specifications of silenx on paper look amazing but it could just be an entirely different way of measuring the noise level, and the only way to really compare them would be to use both of the side by side
  10. theflinger
    theflinger What's a Dremel?
    21 Mar 2004
    I remember reading on a fan site that 14 dbA is quieter than they could measure....seemed a bit ridiculous but the fan has to make some sound, you cannot stop the sound of air moving, haha.
  11. Nexxo
    23 Oct 2001
    Oh, alright then. For all your silent 120mm fan cooling needs: go for a Panaflo FBA-12G12L:
    Air Flow: 68.9 CFM
    Fan Speed: 1700 RPM
    Noise Level: 30 dBA
    Power: 2.6 watt
    Bearing Type: Hydro Wave Bearing
    Fan Size: 120x120x38mm
    Else, NMB makes some nice quiet fans, but they're harder to obtain.
    Also, visit Silent PC for more info on quiet fans. :thumb:
