Graphics ATi 5850 on 400w?
Discussion in 'Hardware' started by shaunboy, 3 Apr 2011.
  1. shaunboy
    shaunboy Phenom II's are cool guys
    31 Jan 2010
    So I just orderd a 5850 from Overclockers for a very good price but I suspect my PSU may not be up to the challange but comparing power consuption of my current card and the 5850 they seem to be relatively the same.
    What do you guys think?
    The PSU is the now discontinued Corsair CX400 btw.
  2. murraynt
    murraynt Well-Known Member
    6 Jun 2009
    I say you should get away with it. It not like you have a 990X overclocked.
  3. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  4. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Like fingers has shown, you'll be fine.
    I've seen a GTX480 running off a 450w PSU, so a 5850 will be no issue for a 400w.
  5. Fingers66
    30 Apr 2010
  6. shaunboy
    31 Jan 2010
    Thanks for clarification guys, in the coming months I may buy a better, modular PSU
  7. xXSebaSXx
    xXSebaSXx Active Member
    21 Aug 2010
    I have a 955BE + HD 6950 + 48W Fan running off of a VX450 and it is enough. I should guess your 555BE + 5850 should be ok on the CX400
  8. Marine-RX179
    Marine-RX179 New Member
    24 May 2010
    I would definitely recommend trying to unlock your Phenom II X2 550 if not already done so, and overclock it as well. Even my Q6600 at 3.6GHz would bottleneck my overclocked 5850 a bit...in games that are slightly more CPU demanding and don't use more than two cores.
  9. shaunboy
    31 Jan 2010
    I've tried to unlock the CPU but the other two cores are defunct. I will probably overclock over what I already have, its at 3.4GHz right now.
  10. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    It doesn't really matter what the PSU's Watt rating is but how many Amps you got on your 12v rails. Your PSU has a single 30A 12v rail and a 5850 needs 13A (155w) at load. So you should be alright. Still would be an idea to upgrade when you can though.
