Cases ATi 5870 & 5850
Discussion in 'Hardware' started by ciff1, 10 Oct 2009.
  1. ciff1
    ciff1 New Member
    28 Apr 2009
    Looking to build new i7 (1366) rig after christmas, but how many cases can accomodate these 11" long gpu's. Looking at this months premium player :confused:as a base but without the ssd and just a xfi extreme gamer sound card. Just that the cooler master 840 is such a big bland case, good for air cooling but no window etc.
    Why do gpu manufactures keep designing longer gpu's as they only fit the huge high end cases!
    Budget £1500 but also have to allow for gaming keyboard and new 2.1 speakers and 22" monitor.
  2. gaz_360
    gaz_360 Make that change
    24 Apr 2009
    May not be your first choice to look at maplins, but sometimes they have some pretty good stuff, I got this case on offer about 7 months ago for £29.99. It has more than enough space for a 5870.
    Gaz :D
  3. Threefiguremini
    Threefiguremini New Member
    13 Sep 2009
    I went with the coolermaster haf 922. Good quality case and big enough for large graphics cards
  4. heir flick
    heir flick Active Member
    2 Feb 2007
    i have a nzxt apollo case and was not sure if a 5870 would fit so contacted nzxt and they tried it for me and said that indeed the 5870 did fit but only just
  5. wartank
    wartank New Member
    3 Jan 2010
    hi heir flick, just wondering if you ever got that 5870 for your apollo? im measuring my case and i dont seem to have 11 inches im looking at 10.75max, did you remove the hard drive cage i think it fits without the cage but i would rather keep the cage if possible? Thanks
    Edited
    On a closer look at my case (nzxt apollo) the distance from the back of the case to the hard drive cage is actually about 28cm which is right on 11 inches.
  6. Alexg
    Alexg New Member
    2 Jan 2010
    The 5850 is smaller than the width of an atx motherboard, will fit in most cases no problem.
  7. heir flick
    2 Feb 2007
    wartank, i could not find a 5870 anywhere so went for a pair of 5770's
  8. evoyear
    evoyear New Member
    10 Sep 2008
    that's what i thought
  9. radeon2010
    radeon2010 New Member
    6 Jan 2010
    The Nvidia GF 3D Vision Kit is suitable for you.
    link
