Graphics ATI 9200SE, Gf4 MX 440, tv tuner
Discussion in 'Hardware' started by Ben, 3 Jul 2004.
  1. Ben
    Ben What's a Dremel?
    11 Aug 2003
    what would be the better card
    Gf4 MX 440 64MB £??
    or
    ATI 9200SE 64MB £30
    and what would be a good make to look at for a tv tuner only needs to have tv in put, cost about £20 probably get some thing from ebay.
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    If you just want to use the gfx cards for tv out for a htpc/pvr etc and your using SDTV (standard definationTV) and not HDTV (High defination TV) then the gf 440mx is better in my view (I have both 440mx and 9200 in my pvr pcs). The reason being is that ATI reds tend to bleed on SDTV resolution.
    For gaming then the GF440mx is faster but not a lot and both are not really gaming cards.
    For a cheap tv tuner card look for a card with SAA7133/4 chip (4 is for PAL and 3 is NTSC going from memory but could be wrong) I believe Aldi are doing an Tevion (Rebranded K-world) xpert 7134 for £25.
  3. Ben
    11 Aug 2003
    thanks
    are any of these any good
    can they do both tv in and out at the same time::
    5
    or are the newer ones much better
    edit:: it will only be playing videos and recording tv.
    rest of the system so far::
    amd xp 2000
    Msi kt4v
    128 ddr ram (pc 2100)
  4. star882
    star882 What's a Dremel?
    19 Mar 2003
    Well, my Dell PC with a Radeon 9000 Pro AIW works really well for HDTV, and I haven't seen a problem when viewing DVDs or web videos (which are about SDTV resolution).
  5. Monster63385
    Monster63385 What's a Dremel?
    18 Mar 2004
    if a tv tuner is all you want then just a stand alone tv tuner card, no sense in buying a whole new video card. I still use my original radeon AIW for my pvr machine, with a 1 gig p3 and 512MB memory, works great. besides i couldn't see myself throwing away a video card that i payed over 400 dollars for when it was new. :wallbash: man i hate computers!!
  6. herbs
    7 May 2001
    The ATi All-in-wonder 9000 would be the best out of that lot. Going from memory the mm100 and mm200 (they look similar to the first 2 in your list) don't work with XP as there are no drivers. Well there are standard BT8x8 drivers but the sound doesn't work for the cards.
    It's apparently a common problem with the tv out on the cheaper ATI cards (cost cutting), I don't see it on my card but I'm not that fussy on the picture or sound quality.
    Also if your using HDTV then you won't be using s-vid as s-vid doesn't provide enough info.
    If you want a tv card I have an old BT878a card for a £10er. Just message me for info.
  7. star882
    19 Mar 2003
    That's why good monitors use DVI or VGA.
    According to a file I downloaded a few months ago, you need a video card with an integrated MPEG-2 decoder (Radeon series) for DTV to work.
  8. Ben
    11 Aug 2003
    alfer alot of looking a round i have desided to wate a bit as i can get the 9200se new for £20 in ~2weeks and my other system the motherboard is being replaced.
