Linux ATi AIW 8500 DV under Ubuntu 6.10
Discussion in 'Software' started by Cthippo, 12 Jan 2007.
  1. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    This seems to be a common problem, but I haven't seen a satisfactory answer for it.
    I installed Ubuntu 6.10 Edgy from the live CD and can't get my video card to work properly. If I boot from the live CD with "safe display drivers" it works fine, but when I installed it from there it gets to the splash screen and then my monitor stops getting signal. How do I either change my installation or get it to re-install with the safe drivers?
    Hardware is an ATI AIW 8500 DV. I don't care about the TV in features, I just want the video to work.
  2. Glider
    Glider /dev/null
    2 Aug 2005
    You could try running a live cd that works, mount the / harddrive, copy over the xorg.conf and reboot?
  3. Elv13
    Elv13 What's a Dremel?
    26 Apr 2006
    boot on live-cd, open terminal
    mkdir /mnt/install
    mount /dev/*d** /mnt/install ## change *h** by hda2 or the right device where is ubuntu
    sudo cp /etc/X11/xorg.conf /mnt/install/etx/X11/xorg.conf
  4. Glider
    Glider /dev/null
    2 Aug 2005
    Like I said ;)
  5. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Boot to command line then install the closed ati drivers.
    Google = ati+ubuntu
  6. lcdguy
    lcdguy Minimodder
    25 May 2004
    i ran into the same issue with my X1900XT with ubuntu, freebsd, fedora core. About the only one what seemed to be have was suse. In the end i went back to windows so save my sanity for a little while. I would try the live cd route thats been mentioned. If that doesn't work i would try loading suse and see how that goes.
  7. AJB2K3
    12 Dec 2005
    If you read the forum guides it takes only a few minits to get ati cards working.
