Graphics ATI Catalyst Control Center
Discussion in 'Hardware' started by cool_dude, 20 May 2010.
  1. cool_dude
    cool_dude Minimodder
    26 Aug 2004
    Hey
    Just wondering quickly if anyone knows where i can get it to auto-start up with windows?
    It was working fine on my mates pc, but for some reason it has stopped and now it doesn't auto-start.
    Its for fan purposes, as the graphics card fan runs too low on idle therefore I need the control center to ramp it up a bit.
    I can get into it by accessing the application itself, but I need it to auto-run when others use the pc.
    can anyone help? I'm on nvidia myself at the moment - its for my mate therefore can't access the pc directly at the moment and would like it sorted asap.
    thanks peeps :)
  2. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Open it up, go into options and Preferences, tick Enable System Tray Menu.
    Failing that, reinstall it. It should reset the service.
  3. bulldogjeff
    2 Mar 2010
    click start then in the search bar type msconfig, then hit enter, click start up box and see if it's in the start up menu and make sure it's ticked
  4. cool_dude
    26 Aug 2004
    thanks will give them a go.
    anymore suggestions incase they don't work are welcome!
  5. marc.knuckle
    marc.knuckle What's a Dremel?
    19 May 2010
    the preferences one should work, if not, in the same options menu, restore to defaults as i believe the default is to start with windows
  6. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    This happened to me, and I just had to do a reinstall.
  7. cool_dude
    26 Aug 2004
    thanks
    What methods to re-install? Driversweep and all that or just 'repair' via the setup.exe?
  8. Glix
    Glix Left Thumb Stick in the mud.
    11 May 2010
    Just the usual ATI uninstall from CP. I've had this bug happen a few times to me with previous versions of CCC, where it doesn't start with Windows and right clicking desktop fails to bring it up.
  9. Pete J
    Pete J Employed scum
    28 Sep 2009
    Another option is to use MSI Afterburner. You can set up a more advanced profile if you want.
  10. philheckler
    philheckler Used to be a pc enthusiast
    23 Apr 2009
    +1 for msi afterburner - it's got a nice gui for fan control....
