Graphics ATI Drivers
Discussion in 'Hardware' started by P2D, 2 Oct 2005.
  1. P2D
    P2D 99.999% Pure Spam!
    26 Mar 2004
    probaly a really lame question, but it is OK to put the latest 5.9 ATI drivers onto my laptops Mobility x700? Only asking because on the ATI website they have a section for Laptop graphics cards, but the little tool that checks said mine wouldnt support it?
  2. robbybertu15
    robbybertu15 <b>needs a job</b>
    28 Feb 2005
    With the 5.9 drivers, yes.
  3. P2D
    26 Mar 2004
    Okay, I just tried to install them and it said "Sereve - inf error Video driver not found", then it said in a different box "Setup was unable to complete the install, try to setup your display adapter with a standard VGA driver before running setup"..and wouldnt let me install it? Ideas?
  4. TMM
    TMM Modder
    12 Jan 2004
    http://support.ati.com/ics/support/default.asp?deptID=894&task=knowledge&questionID=19546
    if you can't pass that, then i don't know how you can update. there may be a 3rd party site with the actual driver *looks*
    edit: http://downloads.guru3d.com/download.php?det=1186
    :thumb:
    i believe its the driver that gets downloaded with the updater thing (haha technical..), but implemented into the desktop version of the Cat 5.9 CCC :)
  5. P2D
    26 Mar 2004
    Damn, Still no luck, thanks for trying tho bud!.
    Anyone else got any ideas?
    same error too..(CCC installed fine then deleted itsself when i put the orgional drivers back on, from the driver disk i got with the lappy.wtf?)
    Guess i`ll be stuck with these drivers tho, and i cant get CCC either, *crys
  6. kenco_uk
    28 Nov 2003
    http://www.ati.com/online/mobilecatalyst/
    Might work. Personally, with 5.8, I got hold of DHModTool 2.2 and modded the standard drivers - on reboot it seems to be working 100%. I'm just trying to find where I d/l the dhmodtool from!
    Ah, here we go..
    http://www.driverheaven.net/patje/
    Just to confirm, I've just installed Cat5.9 (the full desktop version) on my lappy (acer aspire 1672wmli - ati 9700) using dhmodtool 3.
  7. P2D
    26 Mar 2004
    nice one Kenco, Installed and its running fine! :thumb:
    Only problem is the CCC wont start, i clicked the icon, went into its install folder, right click and hit that button, and it wont launch. wtf.
  8. P2D
    26 Mar 2004
    Okay, CCC says "you dont have permission to use this program", i tried reinstalling it and then even making another account to try. The account i use is the only one on the laptop and is set to admin. ideaS?
    Mike
  9. kenco_uk
    28 Nov 2003
    hmm.. silly question, but do you have .net and associated updates installed from windows update?
  10. P2D
    26 Mar 2004
    Yep.. done it all...
