Graphics ATI Radeon 9800XT
Discussion in 'Hardware' started by hydro_electric_655, 18 Jul 2006.
  1. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I have had this card for years now. I am planning on making a new comp with a BFG GeForce 7900GTX OC but for now my radeon card has a bad fan that worked fine up until last year. The temps are 85+ idle and probably a littel higher laoded. ANy ideas?
  2. DougEdey
    5 Jul 2005
    :O turn it off!
    Then get something like an arctic silencer, not sure what country you're in so I can't recommend a supplier
  3. hydro_electric_655
    13 Jul 2006
    Right now I just got on the computer after a hour or 2 of screen saver and its at 91C and has a 412mhz clock rate. I live in the us.
  4. Fr4nk
    Fr4nk Tyrannosaurus Alan !
    12 Mar 2005
    Have a look around newegg or somewhere for a new cooler, it shouldn't be that expeisive. You do realise you'll probably kill the card if you game with it with no fan :|
  5. hydro_electric_655
    13 Jul 2006
    It has a fan the stock fan
    thats my worry,
  6. lcdguy
    lcdguy Minimodder
    25 May 2004
    A. it's a 9800 so likes are it's out of warranty by now
    B. get an artic silencer or just get a house fan direct it on the card
    try running the computer with the side panel off :D
  7. hydro_electric_655
    13 Jul 2006
    Trust me its been off for a long time. Probably out of warranty. I tried taking the fan off but I didn't ever get it off. And risking breaking my only comuter and a once $500 GC and killing my only computer was unsettling.
  8. DougEdey
    5 Jul 2005
  9. hydro_electric_655
    13 Jul 2006
    One quick question. I can't push my monitor above 1280x1024 the monitors reports ddc settings max 1920x1280 but I can't get my card to go past 1280x1024 im using the ati standard display settings in windows. Any ideas?
  10. Krikkit
    21 Jan 2003
    Does your monitor actually support resolutions above 1280*1024? That's usually the problem. With my CRT, the slider goes all the way to its (and my graphics card's) max res of 2048*1536.
  11. hydro_electric_655
    13 Jul 2006
    well I used Catalyst and got it up to higher esolutions but they aren't sqaure anyway my monitor won't respond above 1280x1024 no matter that is pretty much the best resolution for working.
  12. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    I second the Arctic Cooling fan suggestion. I've still got a couple of 9800 Pro's with those on 'em, and I've never had a problem ;)
    What size/make/model monitor are you using btw?
  13. hydro_electric_655
    13 Jul 2006
    Samsung SyncMaster 712N
