Graphics ATI Remote Wonder without an ATI card
Discussion in 'Hardware' started by RedBuddies, 28 Jan 2006.
  1. RedBuddies
    RedBuddies What's a Dremel?
    10 Oct 2005
    Hi,
    My father just bought himself an ATI All-In-Wonder graphic card with the Remote Wonder system. I was wondering if it was possible to hook the remote system onto another computer that doesn't have an ATI graphic card.
    I have another ATI card but it isin't an All-In-Wonder and I don't want to use it as my primary graphic card as it is just a poor Rage II :/.
  2. Hybr1d
    Hybr1d Bаnned
    13 Dec 2005
    ATI Remote Wonder without an ATI card.
    That's like having a penis without being a man!
  3. specofdust
    specofdust Banned
    26 Feb 2005
    I think one can assume from Hybr1ds remark that it is not possible, or if it is, it doesn't work all that effectively.
    However, I don't see any reason why an IR Blaster/Reciever combination couldn't work, or bluetooth control of a computer couldn't work. If you're just wanting to do basic control functions, it should be possible to manage it if you use the remote, along with 3rd part remote software :)
  4. Hybr1d
    Hybr1d Bаnned
    13 Dec 2005
    Never seen Jerry Springer?
  5. star882
    star882 What's a Dremel?
    19 Mar 2003
    It should work. The receiver is separate from the video card.
  6. Malvolio
    Malvolio .
    14 Dec 2003
    I honestly don't know what any of you are smoking, but I can confirm that it will work 100% no problem what so ever with every generation of remote wonder ever made and bundled with every AIW ever made (unless you've got a special cable that connects DIRECTLY to the card, it will work as I've stated).
    Install the RW software off the ATI site, plug in the receiver, and you're set :thumb:
  7. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    I just bought an ATI TV tuner and it came with an ATI Remote Wonder Plus. The devices are all in the same box, but the remote is packaged separately with separate instructions that suggest that it can be sold separately.
    Actually, I'm going to go ahead and install it in my laptop to test this theory out for ya.
  8. Stuey
    20 Jan 2005
    I can confirm, the ATI remotes work without any additional hardware to be installed. Since my last post, I have installed it and used it to control winamp, WMP and mplayerc.
  9. Firehed
    15 Feb 2004
    It works perfectly. I've been doing it for about a year and a half. With a couple different nVidia cards at that.
    I should note that the 2.5.0.0 drivers seemed to work best for me though. It may or may not make a difference for you... and I think that was when I was messing around to covert it to an MCE remote. I don't think they're available for download anymore anyways.
  10. RedBuddies
    10 Oct 2005
    Thanks everyone for your replies :)
