Graphics ATi Vista Drivers
Discussion in 'Hardware' started by MustangX, 9 Dec 2006.
  1. MustangX
    MustangX What's a Dremel?
    9 Dec 2006
    Are there going to be any new drivers released from ATi with support for Vista, besides the Beta ones, that will actually work? Would it also be fine to use either the 6.11 Drivers or the 6.12 Beta drivers for XP with Vista?
  2. Callum
    Callum What's a Dremel?
    4 Apr 2006
    Yes of course there will. Vista hasn't been released yet, that's why they are only beta drivers so far. And I doubt the XP drivers will work well at all.
  3. MustangX
    9 Dec 2006
    Vista has been released... I have it and legally too.
  4. Callum
    4 Apr 2006
    OK, but not to consumers. I imagine the drivers will be there when Vista is actually available.
  5. MustangX
    9 Dec 2006
    I was just wondering because the Vista beta drivers ATi has out now causes artifacts in most of the games I own.
  6. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    Quick question, how did you get it so early, and legally?
  7. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    The buisness version of Vista is out for the public now isn't it?
  8. ComputerKing
    8 Sep 2006
    I was Wondering Wich Is the best In Vista
    Like We Use Professional in xp not Home :D
    Thanks I'm Thanking TO get one
  9. MustangX
    9 Dec 2006
    Through being a MSDN subscriber.
  10. Mother-Goose
    Mother-Goose 5 o'clock somewhere
    22 Jul 2004
    MustangX - use the RC1 ATi drivers, they are stable, the RC2 ones will bollox it to high heaven (had any problems shutting down?)
  11. MustangX
    9 Dec 2006
    Not usually, but if I exit out of a game then right after that shutdown it takes a slight bit longer. I'm downloading the RC1 Drivers right now.
    Edit: I installed the Drivers but still does the same thing. Also, I do not have my video card overclocked. What I didn't do though was the run the DriverCleaner. Would that make a difference or not?
    Here's an example I get of artifacts in Counter-Strike: Source...
    http://img507.imageshack.us/img507/8198/artifactingep3.jpg
