Graphics ati x1400 or nvidia GEforce 7600?
Discussion in 'Hardware' started by jimaras1, 18 Dec 2006.
  1. jimaras1
    jimaras1 What's a Dremel?
    18 Dec 2006
    hi everybody. i am close in buying a new laptop and i am in a great dilema. i might buy a fujitsu siemens INTEL 2 DUO CORE 7200 2G ram with ati 1400 and with a 128 dedicated ram up to 512 and a toshiba intel 2 duo core 1.83 MHZ 1G ram with nvidia GEFORCE 7600 256 ram. i want to play games. which one i can choose?
  2. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Just a guess but I'd say the Ati would be better since even though it has shared RAM the laptop has more RAM in the first place, and would be better
  3. atanum141
    22 Jul 2004
    7600 no contest.
  4. Gravemind123
    Gravemind123 avatar not found
    26 Aug 2006
    The 7600 is much higher powered, and if you really need more ram, you can upgrade it, unlike video card which you can't change
  5. BFGunrunner
    BFGunrunner What's a Dremel?
    13 Mar 2006
    Coming form a 7600 GT owner i's say go for the 7600! My freind has a X1600pro 512 mb with an AMD 64 3400+ and I still get better resluts in every game except for Far cry.
  6. sandys
    sandys Multimodder
    26 Mar 2006
    I have a 7600 in my laptop its not bad but there are two versions one with 64bit memory and one with 128bit memory obviously the former is a lot slower, my laptop has the 64bit one its 256Mb but only 128Mb is real the other is turbocache, not sure what the toshiba is (7600 64/128 or GT ) but even if its the slow one like mine it will still be better than a x1400.
    As an indicator for performance look here
    http://www.notebookcheck.net/Mobile-Graphics-Cards-Benchmark-List.844.0.html
    My 7600 with a C2D 1.83Ghz scores 1600 in 3dm06.
  7. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    The 7600 will outperform the X1400. There's really not much of a contest there. If it was a X1650, it might be closer.
  8. drag
    drag Banned
    19 Dec 2006
    always choose nvidia
  9. Techno-Dann
    22 Jan 2005
    Wow, thank you for that thoughtful, well-worded comment.
    And, just for the rebuttal, wait for R600 before spending the tons of cash for a 8800.
