Scratch Build – In Progress Atlas - 18L ATX OC Machine
Discussion in 'Project Logs' started by rogergamer, 13 Oct 2015.
  1. rogergamer
    rogergamer What's a Dremel?
    3 May 2015
    Hello everyone, been lurking for a while here and I'm finally posting my first build log!
    Here is a link of my last build (no log) in case you're curious!
    https://imgur.com/a/g3pBY
    My new build we also be built using makerbeams with a compact and stealth monochrome aesthetic.
    Parts:
    CPU: i5-6600k [Delidded]
    MB: Asus Z170-A
    GPU: Zotac 980 ti AMP! Omega
    Heatsink: Raijintek Pallas Black
    PSU: EVGA 1050 GS
    Ram: HyperX Fury DDR4
    SSD: 850 EVO M.2
    The goal of this build is to compact full size hardware into as small a case as possible without compromising on (cooling) performance and at the same time have a sleek industrial design.
    bird's eye!
    side profile
    sexy ram sticks, the heatsink has surprisingly good clearance
    great looking shroud!
    super compact SSD!
  2. rogergamer
    3 May 2015
    At this point I still don't have my PSU and GPU and I'm making the best of dimensions provided online, this prototype would probably reformed multiple times before the final build
    makes everything so much easier: a caliper!
    basic components: (different lengths) stealth black aluminum beams, (various) brackets, nuts and bolts, standoffs
    bird's eye
    where the PSU would go + brackets
    side, 30mm standoffs for easier cable management!
    back
  3. rogergamer
    3 May 2015
    half a frame completed at the end of the day/night!
  4. neilhart
    neilhart What's a Dremel?
    2 Feb 2011
    Well you have my attention. I have a MakerBeam starter set gathering dust and I am toying with the idea of building a Mini ITX system with the new tech.
    Good modding,
    neil
  5. rogergamer
    3 May 2015
    It's easy and fun! I would definitely recommend it!
    PS: PSU is supposedly arriving tmr, and my 980 ti G1 is probably getting here next week!
  6. rogergamer
    3 May 2015
    EVGA 1050 GS, perfect fit!
    it's all coming together... sans GPU
    closeup
    I'm still missing some components for the case iteself (brackets, etc) and of course the GPU, though I should have everything by the end of next week!
  7. rogergamer
    3 May 2015
    It's alive!
    Added more to the frame and currently stress testing my 4.8Ghz OC! great bin!
    Edit:
    4.8 did not work over long periods unfortunately, back to 4.7 but still a lot better than the 4.5 for an average skylake cpu!
  8. rogergamer
    3 May 2015
    While waiting for parts I delidded my 6600k! The pallas is decent for its size but it's still a low profile cooler and can't beat out dual towers or water cooling. This is of course all in an effort to sustain my maximum OC! will try to increase clocks again! (my first delid btw, glad I didn't wreck it!)
    razor delid!
    all cleaned up!
    The funny thing is my CLU isn't here yet either.... so can't seal it back just yet...
  9. rogergamer
    3 May 2015
    my tube of CLU finally arrived! asfter some careful pasting and putting my CPU back together... it's alive again!
    Max temps in IBT High 10 loops went from ~94c to ~74c!
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    Nicely done & wow 20c difference. :jawdrop:
  11. rogergamer
    3 May 2015
    Yeah, delidding really helps with thermals. This allows me to go into full OC mode on a low profile cooler without worrying about frying my CPU!
    while waiting for my other building materials, I have been toying with another layout! The specific models are just placeholders to show the layout. Though my ideal compnents for this layout would be:
    • Be Quiet! Dark Rock TF (Beautiful, dark, & effective and just the right heaight)
    • Be Quiet! Dark Power 11 1000W/1200W (High power for SLI and OC, matches the cooler!)
    • Asus 980ti/Fury Strix (2 "wings" on the backside of the rig)
    • EVGA Z170 Cheesecake (All black sleek MB)
    Again, going for a dark, clean aesthetic. I havealready plotted out routing of the PCIE ribbons, and it shouldn't be a problem. This would be expensive though, so ideally for a sponsored build!
  12. rogergamer
    3 May 2015
    Added a gif for a 360 view! what do you think? sorry for the poor quality, gifs have their limits
  13. rogergamer
    3 May 2015
    got some new parts today
    and a new monitor! the crossover 2795, 1440p 105hz! the bezel is quite disgusting, so I will be spray painting it! the stand will be replaced too!
  14. Cheapskate
    13 May 2007
    Layout might bite you in the way of SLI. They don't make extended SLI bridges, and I seem to remember someone having trouble getting a custom made one to work properly.
  15. rogergamer
    3 May 2015
    I see, probably gonna turn to an AMD card then
  16. rogergamer
    3 May 2015
    was just playing around and came up with this for a single card rig
    FYI: the final product won't be just the frames! it would have walls, plates and panels!
  17. rogergamer
    3 May 2015
    Got my hands on a temporary non G1 980 ti and put the whole thing together!
    front
    cool bottom up angle
    all the ports
    The pci-e ribbon will be sprayed black (can arrives tmr!) I made some minor changes in alignment that made the form a more correct rectangle instead of a trapezoidal. All 8 corners were replaced by corner cubes to make the right angles more accurate, and I changed out the MB standoffs for slightly shorter ones. The GPU is very securely held, doesn't really wobble even when you try to shake it.
    All this can be taken apart if I wanted to for a new layout, and nothing is really final untl I have designed and ordered the plates and walls for the rig! hope you are enjoying watching this so far!
    Edit: I will work on cable management more later!
    Edit: just found out the ribbon broke... waiting on replacement now...
    Edit: Ordered a 980 ti AMP! Omega by Zotac instead of the G1! should arrive in a few days!
  18. rogergamer
    3 May 2015
    new layout! pretty sure this is the one I'm going with. Went from 20L down to 16L, pretty nice for a full ATX OC rig! I test fitted the windforce card in there already, and according to my measurements the monster zotac 980 ti should too! (it supposedly arrives tmr) Also added the front panel IO, gonna paint the PCIE ribbon once my gpu gets here and I can test it.[​IMG]
    meanwhile I already tested the plasti dip on a broken ribbon, and the result looks great!
  19. rogergamer
    3 May 2015
    good news and bad news...
    good news, my 980 ti is here!
    ~310mm x 120mm x 55mm
    it is HUGE like trump HUGE.... its as big as the strix but much thicker, so much so that I couldn't fit it in my case.... but that's not the bad news
    bad news is that my mobo decide to **** itself after a bios update and died... RMA is probably gonna take 2 weeks or so...
    but since I had to take everything down I get a shot at the skeleton. It's no longer 16L, it's now 18L to accomodate my frankenstein of a card!
    Also, I ordered new high quality pcie risers from li heat! they cost quite a bit more, but their quality is unbeatable (I used their risers in my last build!)
  20. Cheapskate
    13 May 2007
    Could you have made a raised spot in the case panel for the larger card instead of making the frame bigger?
