Electronics Attemping VERY cheap TFT LCD controller
Discussion in 'Modding' started by ZapWizard, 24 Dec 2002.
  1. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    I was digging through my box of old PC parts, and ran across an old Diamon MM Stealth 3D 3000.
    Not a special card, you can find them VERY easily.
    But I did notice the Feature Connector, curious I looked up the pin-out. (It's called a VESA Feature Connector)
    I found the pin-out here:
    Pin-out
    Well what the connector is really, is a PRE-DAC interface.
    Meaning the image data is still in it's digital state.
    So it sould be able to connect to an LCD, with little conversion.
    Well, I have two Sharp 10in TFT LCD's, VERY NICE, but no controllor card. I got them for $1 and im sure as *&#$ not going to pay $200 to run them!. (Model Sharp LQ10D131)
    So I am trying to figure out how to connect the pre-DAC interface to an LCD, which needs digital in anyways.
    I have the pin-out and schematic of the LCD here:
    Pin-Out
    Schematic
    So the question is how to make these two interface.
    I have search all over, and found this page, which mentions BOTH the LCD I have and the Feature connector.
    But I need translation, (Bable fish dont work well enough)
    Need translation
    If this works you can have a TFT LCD controllor for less than $20!!!
  2. Jaz
    Jaz Banned
    18 Dec 2001
    [9:06pm]« KEHT » give me the page
    [9:07pm] <^Jaz^> http://deneb2.boom.ru/index2.htm
    [9:09pm]« KEHT » ðü
    [9:09pm]« KEHT » hm
    [9:09pm]« KEHT » nice
    [9:09pm]« KEHT » ok
    [9:09pm]« KEHT » in 2words
    [9:09pm]« KEHT » he saying that if u have a oldnotebook
    [9:09pm]« KEHT » u can make it faster
    [9:09pm]« KEHT » probobly tuning
    [9:10pm] <^Jaz^> hmmm
    [9:10pm]« KEHT » u need detailsÉ
    [9:10pm] <^Jaz^> Yeah
    [9:10pm] <^Jaz^> its important
    [9:10pm] <^Jaz^> sorry
    [9:10pm]« KEHT » hm
    [9:10pm]« KEHT » k
    [9:11pm]« KEHT » he missing A pictures
    [9:11pm]« KEHT » on hes web
    [9:11pm]« KEHT » so
    [9:11pm] <^Jaz^> Yeah i know
    [9:12pm]« KEHT » it's saying what cable and what color
    [9:12pm]« KEHT » and
    [9:12pm]« KEHT » he saying
    [9:12pm]« KEHT » u can use the matrix of the notebook
    [9:13pm]« KEHT » ok
    [9:13pm]« KEHT » read it
    [9:13pm] <^Jaz^> ok cheers
    [9:13pm]« KEHT » but i connot translate all that
    [9:13pm]« KEHT » cause it dosent make anysens
    [9:13pm]« KEHT » for me
    [9:13pm]« KEHT » :)
    [9:14pm]« KEHT » he explaing how tuning your old notebook even if he dont work
    [9:14pm]« KEHT » more like use the matrix of the ...book
    [9:14pm]« KEHT » u know what i mean
    [9:14pm]« KEHT » É
    [9:14pm]« KEHT » ?
    [9:15pm] <^Jaz^> well i don't but my mate will
    [9:16pm]« KEHT » is that what u were looking forÉ
  3. ZapWizard
    19 Sep 2002
    This translator worked a bit better, (No offense)
    Translation
    It looks like they have a LCD ripped off a Toshiba laptop (Like me)
    The second paragraph says there is a loop of wire and then another PCB.
    From that PCB there are two loops, with 20 conductors
    (So far this is exactly what I have)
    He names the pins...
    He then says he connects them to the "Feature connector" on his S3Virge DX (26pins)
    It looks like he has two wires tied to each data bit.
    The only thing is, I don't know if it worked for him.
    There is supposed to be a image but it's not there.
    I will try later, if it works, you can put a 10 inch LCD in a PC for less than $20!
  4. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    Do you know if the panel is 3.3V or 5V? I don't see a +V pin on the card's connector list.
    oh, btw. You know it's only a 12bit screen, yea?
  5. bradford010
    7 Dec 2001
    nm, it's 5V (on a 31 pin hirose connector as well, predictably) which means it's a TTL interface.
  6. ZapWizard
    19 Sep 2002
    It's 5volts, the full specification is linked up there.
    I got these LCD's for $1.00 Can't complain!
    I bought them to rip out the inverters and the cold cathodes.
    (8 Inch white CCFT, should work good)
    I only found out later that they are TFT, and good enough res and color for DVD's. Perfect for my media computer.
    640x480x12 4096 colors
    Either way there are only 8 bits on the "Feature connector" so I will only end up with 256 colors.
    BUT if it works, it sould be better than those people who put 6 inch Composite Car LCD's in their PC.
    I will have to work on it after christmas.
  7. hydrogen18
    hydrogen18 Banned
    19 Jun 2002
    cool zap, never thought of this b4...anyhow i think all cards have an equivalent of this just the the manufacturers stopped sordering headers onto them after a while...my 9500 pro has an area where a header would be sordered on to...i may sorder one on soon if I can get the pinouts...someone got the spec sheets for a 9500 pro?
  8. bradford010
    7 Dec 2001
    Sorry to disappoint you Zap, but a 12bit panel isn't enough for video playback. :sigh:
    Anyhow, good luck m8! :D Unfortunately, i just dug out the link to the page of the guy who's done it before (IRC) and the page looks dead.
  9. ZapWizard
    19 Sep 2002
    We will see. dont kill it before it's started.
  10. bradford010
    7 Dec 2001
    Doesn't mean you can't do it. The res is plenty enough to run monitoring software and various other visual apps that have to display text.
    But the colour depth just isn't there for any decent quality :)
  11. Lovah
    Lovah Apple and Canon fanboy
    10 Jul 2002
    Let me get this right
    I olso have a toshiba TFT screen (of a toshiba satellite 2060)
    and I've been searching to connect it to my graphics card
    but I dont have such a fancy one ... with the .....port
    is there any way to make a controller from VGA to the TFT screen ??
    (very very cheap)
    cuz u can buy that , but it costs like 200$
    or is that what u were doing ??
    I didnt got the thing about the other port on your graphics card ...
  12. Deymos
    Deymos What's a Dremel?
    23 Nov 2002
    The Vesa feature connector is a 26 pin connector u may find on old vid cards, like the Diamond MM 3d 3000, or a 3dfx Voodoo (for example, I have a Jazz Voodoo rush that has the same connector)
    If u have an old vid card it may be possible that it has the connector onto it. :lol:
  13. Lovah
    10 Jul 2002
    Ok , thanks
    I guess I'll have to look in the 'old graphic cards - bos' :)
    lol
    thanks
  14. kt3946
    kt3946 What's a Dremel?
    17 Feb 2004
    Zap, this has already been done in this forum. Check the LCD sticky at the top, as they have instructions there.
    Yeah, the biggest problem with this mod is that is only allows for 256 colors. This is because the VESA standard never really took anything further into account, it was more or less abandoned after that.
    What I would *love* to see, is a home-brew version of the Chips & Technologies CT65000 series chip that all these TFT controller mfgs use for the expensive LCD controllers. I know that the CT chips are pretty cheap, but these mfgs have to pay their designers and such, so it justifies their price. A homebrew version wouldn't have all these added expenses, and could probably be made fairly cheap. :sigh:
  15. Atomic
    Atomic Gerwaff
    6 May 2002
    Last post before yours: 25-12-2002, 19:10
    fool :rolleyes:
  16. kt3946
    17 Feb 2004
    Whoops... my bad. Can't figure out how it managed to get bumped to the top of the 'new posts' listing though.... :D
  17. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    A wee bit uncalled for.................
  18. kt3946
    17 Feb 2004
    Thanks Hazer. Yup, I confirmed, I have all posts older than 30 days cut off, and somehow this one still made it in the list. Hmmm.. methinks more buggy forum software.... :sigh:
  19. Atomic
    Atomic Gerwaff
    6 May 2002
    Sorry, I just had a mean streak there :devil:
  20. Munterofamodder
    Munterofamodder What's a Dremel?
    1 Dec 2003
    this thread was linked to recently in a similar topiced thread - maybe its something to do with that? Anyhow, I got my TFT and VESA-connector GC and tried it, but to no joy. Not sure i soldered onto the connector on the TFT the right way round though (I had absolutely no idea which end pin 1 was on!)
