Electronics Attention gurus, new DC fan driver IC
Discussion in 'Modding' started by mod-ern man, 30 Jun 2005.
  1. mod-ern man
    mod-ern man What's a Dremel?
    12 Nov 2002
  2. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    The problem is that not many nerds actually build their own fans, and it would probably be hard to replace existing fan drivers inside fans because of different pinouts.
  3. cpemma
    cpemma Ecky thump
    27 Nov 2001
    The new 4-pin fans can help reduce PWM noise, they separate motor supply from electronics supply.
    More here.
  4. Hazer
    Hazer In time,you too will be relixalated
    14 Apr 2003
    IMO, you can get rid of PWM problems by using a power emitter-follower circuit. Its linear, its cheaper, its easier. And you can use a digital pot to make it fancy.
