Modding Attn: Anodizing People
Discussion in 'Modding' started by ebola_one, 23 Sep 2004.
  1. ebola_one
    ebola_one What's a Dremel?
    22 Sep 2004
    Hiya, has anyone anodised an Evercool Aluminium fan surround/mount?
    This 120mm fan has the ability to detach the blade/motor assembly from the Alu frame. (simply unscrews)
    Just after tips if you DIY'd.
    Cheers.
  2. Exomoto
    Exomoto What's a Dremel?
    21 Sep 2004
    I thought this thread was about trying to annodise a person...
  3. ArtificialHero
    ArtificialHero We were just punking him sir!
    25 May 2004
    Ha, me too, that would be (kinda) cool
  4. ebola_one
    22 Sep 2004
    Lol, anodised Cybermen from Dr Who.
    Hahahaha a bright green K-9
    And a big :sigh: to the young 'uns who don't know what I'm talking about.
    Anyway, back on topic, anyone anodised the fan surround?
  5. Kevin
    Kevin What's a Dremel?
    6 Jun 2001
    hmmm. is it the same as what u can find on performance pcs?
  6. ebola_one
    22 Sep 2004
    Performance PC's being a website I guess?
    I'm fearing the search results from google on that one... :blah:
    I'll look anyway though.
  7. MrBurritoMan
    MrBurritoMan What's a Dremel?
    27 Jun 2004
    There is a post on this website about anodizing(correct spelling) stuff. I think that one of the moderators wrote it. Anyhow use the search button. or try google!! :search:
  8. MrBadidea
    MrBadidea What's a Dremel?
    10 Nov 2001
    Aslong as you can completely remove any trace of any other material on the material itself, it should be fine.
  9. toyomatt84
    toyomatt84 What's a Dremel?
    1 Jun 2004
    Here's what I would do if I were you.
    Clean off the fan of any oils, with some alcohol and cloth.
    Get a can of DupliColor's Metalcast and just spray directly onto it.
    Smile at a job well done. :D
  10. MrBadidea
    10 Nov 2001
    If only it were that easy... it would never be anywhere close to looking like it was anodised :waah:
    I've had my entire PC60 anodised Red, and if you could see it in person, you'd definately understand!
  11. toyomatt84
    1 Jun 2004
    Umm, I've personally used the stuff before. It has a Metalcast basecoat that you can lay down, that will give a rougher texture to it. Believe me, it's darn close to the real thing.
  12. retrogamer
    retrogamer What's a Dremel?
    23 Aug 2004
    can you post your anodised PC please? ive never seen anything anodised before :) does it look cool?
  13. MrBadidea
    10 Nov 2001
  14. retrogamer
    23 Aug 2004
    :jawdrop: wow!!! that does look super sexeh :naughty:
    tis a bit expensive for me to do, especially to a full case tho :S very nice clean look tho :thumb:
  15. MrBadidea
    10 Nov 2001
    Thats a common mis-conception. Most big Anodising companies will charge a minimum fee that will cover so much surface area. You get one blanking plate done, it'll cost you the same as a whole case.
    The place I used charged £55 as the minimum, and I worked out I could have had 3 complete cases done!
  16. ebola_one
    22 Sep 2004
    Actually, I did read that thread, but I was after hints specific to the fan surround.
    I also googled, and guess what? I found lots of "articles" on anodising that were exactly the same (got plagerism? :blah: )
    Doesn't matter, I posted the surround off to an anodiser & all it'll cost me is $20nz (roughly £6)
