Modding ATX I/O back plane template
Discussion in 'Modding' started by BlackFlux, 6 Feb 2004.
  1. BlackFlux
    BlackFlux What's a Dremel?
    17 Jan 2002
    Im looking for an actual size template for the I/O back plane of an ATX case.
    I checked formfactors.org but theirs are not full size.
  2. BlackFlux
    17 Jan 2002
    ***Bump***
  3. Langer
    Langer Jesse Lang
    24 Jan 2004
    I've wondered this for quite some time. what does "bump" mean?
    also if you want I could rip the back off an old case and scan it at 100%.
  4. death_star
    death_star What's a Dremel?
    14 Jul 2003
    Bump means to bump the thread to the top of the page.
  5. Langer
    Langer Jesse Lang
    24 Jan 2004
    Thanks.
  6. Nexxo
    23 Oct 2001
    Go to one of those second-hand computer shops, or a computer fair. There you can pick up loads of backplates, for less than a quid each.
  7. BlackFlux
    17 Jan 2002
    Nexxo that would mess up the whole case being made out of arcylic theme...
    Come one ppl where are all the mod gods when you need them? :waah:
  8. BlackFlux
    17 Jan 2002
    Jesse hook that up!
  9. Langer
    Langer Jesse Lang
    24 Jan 2004
    Do you just want the intracate mobo tray part? or the PCI card too?
  10. BlackFlux
    17 Jan 2002
    Actually I need PCI/AGP slots more than the I/O...
    Thanks
  11. Langer
    Langer Jesse Lang
    24 Jan 2004
    The quality isnt that great.Puzzling its a professional scanner?...but the dimentions are right...
    sorry it took so long those antec cases have alot of rivets.
  12. Nexxo
    23 Oct 2001
    I meant you could pick up an old backplate and use it as a template! :duh: In any case, you can buy acrylic IO backplates for three dollars, and acrylic motherboard mounting plates (inc. PCI slots) for 10 dollars to fit an acrylic case, at Clear Computer Cases.
  13. apoogod
    apoogod trix arent just for kids
    19 Jun 2002
    do you mean a CAD template...I to am looking for one.
  14. Langer
    Langer Jesse Lang
    24 Jan 2004
    I suppose I could make a template in SolidWorks, AutoCAD, Maya, 3D studio max...what do you need a template of and what file format?
  15. BlackFlux
    17 Jan 2002
    Jesse, either gif or jpg would be ok.
