Does anyone know where, or have an ATX mobo template? I have not fully commited on the board I want to get; however, it's down to Gigabyte or Abit. Are the mounting holes standard between all ATX boards, or do standard trays have alot of holes to accomidate differnt brands of motherboards? What I would like is a template of the dimentions of a motherboard, and a map of the mounting holes (and maybe the locations of I/O ports if possible) in relation to the edges of the boards. Thanks!
All ATX mounting point are the same....hence the form factor ATX. if u use the google then u would have found THIS as a result
Awesome...Thanks! I was actually looking at that, but didn't read far enough through the document the find the schematic. I commend you on your lack of laziness and pointing out mine Really, thank you.
I was always wondering if anyone ever took the time to make a printable ATX template. Would be lovely to cut one out of hardboard or something.
