Audigy keeps getting too loud! HELP!
Discussion in 'Hardware' started by seb835, 22 Apr 2002.
  1. seb835
    seb835 What's a Dremel?
    31 Jan 2002
    After finally getting my Audigy to work in Win XP i now have nother prob. If i install the sofware and like the mixer and audioHQ control panel and stuff, then whenever i reset my comp and windows reloads, the volume is too high and everything sounds distorted until i briefly click the volume slider in te mixer...
    why on earth does it do this? is there a fix?
    cheers
  2. Guest-16
    Guest-16 Guest
    i used to get that too, dunno how i cured it. Just seemed to rectify itself!?! u tryed getting the latest drivers from creative?
  3. seb835
    31 Jan 2002
    yeah tried the XP update and its fine now
    its such a dodgy card, it cannot be installed unless you install windows with the card in the PCI slot already.
    but the sound quality is incredible i think youll agree :)
  4. acron^
    acron^ ePeen++;
    15 Oct 2001
    Have you tried turning the volume down on your speakers? :eek:
  5. Guest-16
    Guest-16 Guest
    Yea, but every time he reboots the volume gets reset to the top.
  6. acron^
    acron^ ePeen++;
    15 Oct 2001
    Hmmm, i'll research it a lil and get back if I find anything.
    Keep us updated seb.
  7. seb835
    31 Jan 2002
    thanks its ok, i re applied the XP update and its alright now
