A/V Audio Splitter & Two Sets of Speakers Ques
Discussion in 'Hardware' started by Zabuza, 4 Sep 2012.
  1. Zabuza
    Zabuza New Member
    5 Dec 2009
    Hi all,
    I currently have a Genius Speaker 2.1 SW-N2.1 1100 system, which is nice, but I'd like more for movies and music so was thinking of Microlab Solo 6c. My question is, if I were to use an audio splitter to use both sets, would I suffer from loss of sound quality?
    I have also recently ordered a ASUS - Xonar DX 7.1-Channel PCI-E Sound Card and wondered whether I could just plug one set of speakers into this card and one into mobo and if that'd work?
    Cheers.
  2. Deders
    Deders Well-Known Member
    14 Nov 2010
    I have all my speakers doubled up via splitters, sounds awesome. If you were to have one in each card you'd have to assign which programs used which card, don't think you could have both at once.
    You could set it up as a 4.1 setup also if you used the microlabs as rear speakers, or the other way around. I used to have a 4.0 setup and the rear speakers were slightly bassier which sounded great in films. I think I'd prefer to have a sub at the front though.
  3. Lance
    Lance Ender of discussions.
    6 May 2010
    Get yourself a Digital amplifier like this:
  4. Zabuza
    Zabuza New Member
    5 Dec 2009
    Suppose I may as well use a splitter if you didn't notice any quality reduction. Seems like the easiest solution.
  5. Tangster
    23 May 2009
    Splitters will cause a reduction in audio volume due to the increased resistance. Aside from that, I can't think of problems with a splitter unless it's really bad quality.
  6. lp rob1
    lp rob1 New Member
    14 Jun 2010
    Actually, splitters cause a decrease in resistance, due to the resistors (speakers) being in parallel, and the total resistance in a parallel circuit is 1 / ( 1/R1 + 1/R2 + ... + 1/Rn ). The decrease in resistance creates a larger load for the audio circuit, but as the current is usually limited, each speaker gets an overall lower current.
  7. Tangster
    23 May 2009
    Derp. I should really know that.
