Graphics audio/video Input?
Discussion in 'Hardware' started by led_zeppelinzoso, 25 Jul 2006.
  1. led_zeppelinzoso
    led_zeppelinzoso What's a Dremel?
    13 Jul 2006
    Ok, I’m looking for something to take analog audio/video (i.e. Move camera, or VCR) through RCA’s or S Video, to my pc. I’ve been told that almost any video card will do this, but don’t video cards have outputs, not inputs, I don’t know so that’s why I’m asking. So if some video cards do this, which ones would have the highest video quality?
    I know there are things you can buy that work through USB, but they turn out looking like they’ve been recorded with a web cam.
  2. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    You will need a special card for that. Probably some type of input card. I know that bit-tech reviewed a usb unit but for audio just get a adapter and hook it up. via microphone or audio device.
  3. Guest-16
    Guest-16 Guest
    You need a card with VIVO: Video in, video out. They generally all have very similar qualities, although personally I prefer the ATI rage theatre chipsets on ATI cards.
  4. led_zeppelinzoso
    13 Jul 2006
    I looked at some ATI cards with VIVO, and there all like 600 bucks. I'm only going to be using the card for importing video so I can edit and store it. I don’t need any of the other features, so do they have a model that has the same VIVO input quality, but on a more striped down cheaper card?
    Like, does the $660 card have better input quality compared to a $150, or does the $660 just have more features but the same input quality?
  5. hydro_electric_655
    13 Jul 2006
  6. Guest-16
    Guest-16 Guest
    Dont confuse Avivo with VIVO. They do tend to put them on the more expensive cards, yes, and im not entirely sure why.
  7. ch424
    ch424 Design Warrior
    26 May 2004
    Two questions, Bindi:
    Is the Rage Theater chip fast enough to use for playing console games through the graphics card and onto your computer monitor?
    What software do you use?
    Thanks
    ch424
  8. Guest-16
    Guest-16 Guest
    Usually video in suffers from lag. Ive tried it on an oooold Radeon VIVO and I havent heard anyone since who's got it to work and not have a notiable lag between controller and movement on screen.
  9. led_zeppelinzoso
    13 Jul 2006
    What’s the difference between VIVO and Avivo? and is there a card that just does that without all the "extras" that I dont need that drive the price up?
