Case Mod - Complete ⭐ Aura Master
Discussion in 'Project Logs' started by Antera23, 1 Jul 2017.
  1. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Hello everyone!
    DCMM 2017 is coming and I am creating a new computer for that. Until now I built Casecon machines but this time on the request of one of my main sponsors - Cooler Master - I'm building a Casemod computer.
    The base is a Mastercase Maker 5 case.
    My main sponsors are:
    Cooler Master Hungary
    Asus Hungary
    Geil Memory
    TeamGroup Team
    Aquatuning GmbH
    Dremel Hungary
    Thanks for their support!
    My other main sponsor is Asus Hungary and the hardware they donated me shown the direction of the mod.
    The main direction is Asus Aura. I think it's now very popular among both the modding and the end user people.
    The name of the mod is: Aura Master.
    Hardware:
    -CoolerMaster Mastercase Maker 5
    -Cooler Master MasterLiquid Pro 280 /only Cpu block/
    -Cooler Master V1000
    -Cooler Master Masterfan Pro 140 Air Pressure RGB
    -Asus Strix Z270E Gaming
    -Asus Strix GTX 1060 6Gb
    -Intel I5 7500
    -Geil Evo X 4x8 Gb
    -TeamGroup M.2 PCIe SSD P30
    -Alphacool fittings, tubes,radiator
    -Alphacool Nexxxos GPX
    -Alphacool Cape Corp Coolplex pro 15 LT
    I've been experimenting 3 month creating a material which really enhances the show of the RGB lights.
    I think I solved that and the front panel of the case is dedicated to this effect.
    I've designed a fitting plexi tank which is made of 3 parts and held together by 40 screws. This is filled with the liquid and I flow air bubbles through that. The liquid is thicker than water which is needed for the bubbles to float upwards slower.
    The whole tank is surronded by an RGB tape which is connected to the Aura port of the Asus Z270E Gaming mainboard so all lights will by synchronized in the case.
    This unit is called "Liquid RGB ".
  2. Antera23
    Antera23 Minimodder
    14 Jan 2007
  3. Antera23
    Antera23 Minimodder
    14 Jan 2007
  4. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Case upgrade...
  5. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Reservoir homemade. :)
  6. Antera23
    Antera23 Minimodder
    14 Jan 2007
  7. Antera23
    Antera23 Minimodder
    14 Jan 2007
    LED & console.
  8. Antera23
    Antera23 Minimodder
    14 Jan 2007
  9. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Aqua wall test.
  10. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Aqua wall RGB test.
    ....to be continued.
    P.
  11. WanV
    WanV What's a Dremel?
    23 Dec 2016
    wow man what liquid is that? looks so thick
  12. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Own blend, very thick.
  13. Antera23
    Antera23 Minimodder
    14 Jan 2007
    I've built in the new cooler and also made the fixation of the LED console today.
  14. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Led Consol
  15. Antera23
    Antera23 Minimodder
    14 Jan 2007
    I also modified the motherboard tray and cut some holes for the front panel cables.
  16. Antera23
    Antera23 Minimodder
    14 Jan 2007
    I've finished the front part lately. I've painted it and also I welded a stiffening element into its place. The whole part will be painted once more but only when everything will be ready. 11.jpg 12.jpg 13.jpg 14.jpg 15.jpg 16.jpg 17.jpg 18.jpg
  17. Antera23
    Antera23 Minimodder
    14 Jan 2007
    19787080_1736499556364732_1183239470237295472_o.jpg 19731937_1734210009927020_74552807068082318_n.jpg 19780732_1735351326479555_5179140674096796683_o.jpg
    I had to redesign the radiator console on the top of the case to fit the Alphacool radiator and I made a cover plate which I will install tomorrow.
    I'm planning to replace the GPU cooler during the weekend. The new Alphacool Nexxos GTX will be on the ASUS Strix 1060.
  18. Antera23
    Antera23 Minimodder
    14 Jan 2007
    I've finished the radiator lower cover plate today.
    This part will also get a black powder coating.
    19875536_1736497983031556_6322097424872110359_n.jpg 19961212_1736497903031564_7181214560862615548_n.jpg 19905225_1736498136364874_6489376470065377498_n.jpg 19748529_1736498023031552_5509988367008431515_n.jpg 19756382_1736498419698179_846311290380446125_n.jpg 19780765_1736498616364826_217688333987616724_o.jpg 19875426_1736499019698119_7444177782594116345_n.jpg 19983252_1736498796364808_5161033531650451738_o.jpg
  19. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Ready for painting.
    19787465_1736499136364774_1977376389381570346_o.jpg 19800617_1736499223031432_2789377913544426050_o.jpg 19883988_1736499066364781_1135854332519001026_n.jpg 19943046_1736499306364757_7365780172961463747_o.jpg
  20. Antera23
    Antera23 Minimodder
    14 Jan 2007
    As part of the cable management, I've finished the template, made of plexiglass. I'll make the final part according to this.
    18.jpg 19989350_1736499359698085_3366805042796634348_n.jpg 19905050_1736499439698077_7481745910189173534_n.jpg
