Case Mod - Complete ⭐ Aura Master
Discussion in 'Project Logs' started by Antera23, 1 Jul 2017.
  1. Antera23
    Antera23 Minimodder
    14 Jan 2007
    I've started this week at the powder painter. I tried to reach factory quality paint of the modified parts of the CM case.
    Next to some tyre work, I've installed the stunning Nexxxos GTX cooler block from Alphacool on the ASUS 1060 Strix during the rest of the day. This was the third Alphacool block I installed and I have to say it came in a beautiful and practical packaging. It came also with a useful and easy manual, even my son could be able to do the cooler replacement if he was here. Once again a big thanks for Aquatuning GmbH and Alphacool for their support.
  2. Antera23
    Antera23 Minimodder
    14 Jan 2007
    The powder painting was completed on 80% of the case.
    The bottom and back part needs some more work on it, so I left these two to the very end.
    I've put the case together again, to start building in the hardware elements.
    19894709_1740173555997332_5554624121554904962_n.jpg 19895058_1740173915997296_288438032492811235_n.jpg 19905193_1740173682663986_1413865861036630070_n.jpg 19990022_1740174009330620_7847036501838543213_n.jpg 19894953_1740174152663939_588109501628257173_n.jpg 19989501_1740174215997266_391783608847852371_n.jpg 19905378_1740174302663924_8521714878270406139_n.jpg 19959149_1740174399330581_8838756873953870108_n.jpg
    I've replaced the factory windowed side wall to a 6 mm thick glass panel with LED lighting.
    The fixing points of the glass panel was made with 6 mm nuts welded to the edges of the case. So this way the side panel will be fixed at the strongest points of the case.
    I'm going to use OptiWhite glass, because it has the best light transmission.
    This way the glass etchings will be more visible than a regular glass.
  3. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Glass template calibration from plexiglass.
    20117096_1743946558953365_1794196486381154848_o.jpg 19990070_1743946685620019_6867611937773403731_n.jpg 20017434_1743946815620006_634043769494058687_o.jpg
    Interior glass template.
    3mm glass, black background.
    Sponsor logos sandblasted.
    20023845_1743946262286728_6336773991218990989_o.jpg 20157355_1743946482286706_5852892450617504414_o.jpg
  4. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Modifying a motherboard tray
    20017691_1743947652286589_8988436698101927158_o.jpg 18.jpg 19905050_1736499439698077_7481745910189173534_n.jpg 19989350_1736499359698085_3366805042796634348_n.jpg 20046668_1744429748905046_673973818845540856_n.jpg 20024002_1744429675571720_9003107403560883477_o.jpg 20157966_1744429855571702_8489764181703505667_o.jpg 20157817_1744430198905001_1989621783683221003_o.jpg
  5. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Thank you for sponsorship from TeamGroup Team!
    Thank You Lilian!
    [​IMG]:) 1.jpg 2.jpg 3.jpg 4.jpg
  6. Antera23
    Antera23 Minimodder
    14 Jan 2007
    In the past few days I've not just worked but build the computer further. I've put the 1060 GTX into its final position. The card was placed in the front of the motherboard, rotated by 90 degrees compared to the original placement. Due to the weight of the card and the Nexxos cooler I had to create proper lower and side fixation points. I'll start planning and building the cooling part during the weekend. After everything will be in place, I'll bring the lower and back part of the case to powder paint.
  7. Antera23
    Antera23 Minimodder
    14 Jan 2007
  8. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Geil Evo X cable mod and policarbonat element next to the motherboard
  9. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Polished steel plate, sand blown GP logo
  10. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Led lighted glass elements.
    6mm Lacobel glass, sand blown logos.
    73.jpg 37.jpg 38 másolata.jpg 32.jpg 47.jpg 49.jpg 50.jpg 51.jpg 31.jpg 75.jpg
  11. Antera23
    Antera23 Minimodder
    14 Jan 2007
    GTX 1060 console
  12. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Current state
  13. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Master Blue.
    :) 76.jpg
  14. Antera23
    Antera23 Minimodder
    14 Jan 2007
  15. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Rear panel , cables sorting....
  16. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Led panel. :)
  17. Antera23
    Antera23 Minimodder
    14 Jan 2007
  18. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Unfortunately the latest water cooling system from CoolerMaster has the same not too fortunate tubing connection as the previous model. I had to modify this to make it compatible with the 1/4 Aquacool connections. Danamid was the base, we turned it into two mid part for the original ports, and then it was fixed with Araldit glue. After four hours of drying I made a test, there is no leaking, mission accomplished.
    110.jpg 112.jpg 113.jpg 114.jpg 116.jpg 119.jpg 121.jpg 122.jpg 123.jpg 124.jpg
  19. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Test , OK!
  20. Antera23
    Antera23 Minimodder
    14 Jan 2007
    PSU and CPU cables , paracord mod, homemade cable comb.
    126.jpg 127.jpg 128.jpg 129.jpg 130.jpg 131.jpg 132.jpg 133.jpg 134.jpg 135.jpg
