Case Mod - Complete ⭐ Aura Master
Discussion in 'Project Logs' started by Antera23, 1 Jul 2017.
  1. Antera23
    Antera23 Minimodder
    14 Jan 2007
  2. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Name plate.
    Stainless steel, polyrose, sandblasted.
  3. Antera23
    Antera23 Minimodder
    14 Jan 2007
    I've made some cover element of wood in the last phase, these will not also hide the cables but also bring some warm feeling to the cold metal case and plexiglass.
  4. Antera23
    Antera23 Minimodder
    14 Jan 2007
  5. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Apart from the M.2 SSD, I've placed an additional SSD at the bottom.
    I've used small furniture parts under the drive to have enough space for the cables under it.
    Two sided adhesive used to fix the part in place.
  6. Antera23
    Antera23 Minimodder
    14 Jan 2007
    I left building the water system at the end of the project. I've used Alphacool petg tubes and connections. I did not use the factory fixations for the reservoir, instead I designed a floating solution. There is no fixation on the top, it is only connected to the radiator using the tube and it is held by an L shape at the bottom. It is a double sheet metal because the reservoir and the fluid is too heavy for the 1mm thick sheet metal. I've heated the tubes with heat gun and bend them with Monsoon profile.
    163.jpg 164.jpg 172.jpg 173.jpg 174.jpg 175.jpg 176.jpg 177.jpg 178.jpg 179.jpg
  7. Antera23
    Antera23 Minimodder
    14 Jan 2007
  8. Antera23
    Antera23 Minimodder
    14 Jan 2007
    I'm using Aquacomputer Double Protect Ultra fluid.
  9. Antera23
    Antera23 Minimodder
    14 Jan 2007
    I had to make a modification on the front panel. The factory ODD covers are installed to the top and bottom. The top cover is modded as the RGB reservoir has two ventilation hole which needs to be open during operation but it has to be closed when moving the computer. To have access to these parts I made the top cover as a door and glued the bottom cover down. I'm drilled and used screws, fixed with glue.
    189.jpg 190.jpg 191.jpg 192.jpg 193.jpg 194.jpg 195.jpg 196,1.jpg 196.jpg 197.jpg
  10. Antera23
    Antera23 Minimodder
    14 Jan 2007
  11. Antera23
    Antera23 Minimodder
    14 Jan 2007
    I've replaced the factory plexiglass cover to safety glass made of 2 x 5mm thick glued brass and transparent glass, drilled 4 places and used 6mm screws to secure.
    I've used Ford carpet studs.
  12. Antera23
    Antera23 Minimodder
    14 Jan 2007
    216.jpg 217.jpg 218.jpg 219.jpg 220.jpg 221.jpg 222.jpg 223.jpg 224,1.jpg 224.jpg What's behind, power supply led modding....
  13. Antera23
    Antera23 Minimodder
    14 Jan 2007
  14. Antera23
    Antera23 Minimodder
    14 Jan 2007
    I've just realized I did not upload photos of the factory case door. Normally this part doesn't have any function on the Mastercase Maker5 case but I gave it a function. I've converted it into a portable speaker of if by using a JBL Go Bluetooth speaker. I've replaced the loudspeaker to a very flat one that fits in the door while it is closed. This way I can unhook the door and bring it with me while enjoying music thanks to the Bluetooth technology.
    227.jpg 229.jpg 230.jpg 232.jpg 233.jpg 234.jpg 235.jpg 237.jpg 239.jpg 240.jpg
  15. Antera23
    Antera23 Minimodder
    14 Jan 2007
  16. Antera23
    Antera23 Minimodder
    14 Jan 2007
  17. Antera23
    Antera23 Minimodder
    14 Jan 2007
    I believe I'm finished with this work log, I already presented the computer at Gamescom / DCMM exhibition. I hope you liked my work.
    The end [​IMG]
  18. Antera23
    Antera23 Minimodder
    14 Jan 2007
    Homemade phone video, sorry...:)
    Professional video a few days later.
  19. Antera23
    Antera23 Minimodder
    14 Jan 2007
