Autdirect 2005FPW
Discussion in 'Hardware' started by Ramble, 29 Apr 2006.
  1. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I've been checking Autdirect for a new stock of Dell 2005FPW's, and I've noticed they have some now.
    As some people have ordered with no problem, I'm wondering, do they come with DVI cables included?
  2. chemo
    chemo True Jungle Brother
    20 Feb 2005
    they do have DVI cables included yes
  3. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Ahh, good.
    Thanks a bunch.
  4. rainbow
    rainbow What's a Dremel?
    2 May 2006
    sorry to bump this but are the monitors from there all good/?
    or have you had bad expeirince?
  5. Shepps
    Shepps Slacking off since 1986..
    5 May 2002
    I bought one in january and even though the box was pretty tatty the monitor was in A1 condition. Came with vga / dvi and power leads. Theres a pretty long thread on hexus's bargin section, most people have had no problems with their monitors. Few people have had pretty bad backlight bleeding which is a known problem with the 2005fpws but autdirect replaced them iirc.
    You should have no problem :)
  6. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I got mine today, and the image is jsut great, and it's a lot bigger than you think it's going to be.
    (Can't see any bleeding either)
  7. kenco_uk
    28 Nov 2003
    Apologies for reviving the thread, but I'm swaying more and more towards buying one of these. I assume recent purchasers have had no problems with backlight problems and that autdirect offer good service? And using one on dvi for PC and vga for xbox360 poses no problems? Many thanks.
  8. hitman012
    hitman012 Minimodder
    6 May 2005
    I wish I never saw this thread... £240? Almost irresistible :(
  9. RTT
    RTT #parp
    12 Mar 2001
    2005s have awful backlight bleeding problems. I wouldn't buy one for 200 quid to use personally (but i'd flog 'em on ebay :D)
  10. Firehed
    15 Feb 2004
    Mine didn't have a whole lot of bleed. I was quite fond of it, though it did end up on the backburner once the 24" came in and ransacked my desk space. Which reminds me, it's unofficially for sale (headed to school, no room for it).
  11. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    I don't really see any problems with the backlight on mine, but some of them have had problems. For that price, I'd go for it.
  12. Panze
    Panze What's a Dremel?
    6 Aug 2006
    Mine's working just fine. No dead pixels and no problems with backlight bleeding.
  13. RTT
    RTT #parp
    12 Mar 2001
    Wanna post a pic? I'd like to see :D
  14. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Although, yes they do have some small problems, they are great monitors, and, unless you stare at black all day, they are invisible.
    How much?
  15. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    They're still in stock mate, just checked.
  16. Veles
    Veles DUR HUR
    18 Nov 2005
    I'm thinking about getting the 2405FPW, good monitor? I'd probably buy it from this shop as they're so cheap.
    Or woudl I be better off getting the 2407WFP?
  17. Panze
    6 Aug 2006
    Not sure how much you get out of this since I couldn't supress the light coming from the window enough to loose the glare. (so you'll just see the window reflection, except in the midle where it's blocked by my chair) And yes the curtains were down. I'd take another pic this evening if I weren't flying for a vacation.
    All I'm saying that when working in a completely black screen in photoshop, background light bleeding, if any, is so insignificant you can't really notice it. Now I've seen some 2005's that have had pretty noticeable bleeding, but I was lucky to get one that has none or very little. Perhaps it has something to do with the fact that my version is one of the last ones made before dell started to offer 2007's.
    As for 2007's and 2407's they have issues with gradient banding when the firmware is older than A02, and you're using DVI connection. link to dell support forum
    2005 and 2405 don't have these banding issues.
  18. Veles
    Veles DUR HUR
    18 Nov 2005
    So if I'm getting an A02 revision 2407 I should be fine? I heard about problems with the new dells but I couldn't quite remember the details of it.
  19. [1N0V471V]
    [1N0V471V] What's a Dremel?
    27 Feb 2006
    Unless you're super super picky the A02 is great... I love it
