Modding Autocad 120mm Fan Profile?
Discussion in 'Modding' started by N4N01D, 14 Aug 2005.
  1. N4N01D
    N4N01D What's a Dremel?
    29 Apr 2004
    Hi, just wondering does anyone have an accurate 120mm fan done in autocad that i could have / use?
    Thanks
    N4N01D
  2. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    I use to have one m8, but I formated to create RAID 0 on my pc. Its easy to make one. Here are the step. For 3D it will be a little harder, but this guid should help.
    Make a box 120mm X 120mm the create and a line fron corner to corner. Were they meat create a cicrle with R 6. BTW make sure you are in mm and 1:1 box and snap. the measure the hole in the fan fro the screw with a drill bit. One by one till the one drill bit fits nicely. Then measure the wall were the screw it and create a line the is the length of the wall of the fan and half the length of the screw.
    I like the KIS method so you can only make 1/4 of the fan and mirror the rest. Good luck m8, this shouldn't take more then 3min to create.
  3. N4N01D
    29 Apr 2004
    aye, but i need very detailed measurements, eg mouting hole dia, the radius on corners etc, i would do it but i dont have a free 120mm fan atm :p and iirc the fans arent exactly 120mm spot on
  4. doryakov
    doryakov What's a Dremel?
    8 Aug 2005
    do you mean to 120mm fan's sketch?
