Development Automatic File Mirroring?
Discussion in 'Software' started by jezmck, 20 Jul 2005.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    Hi,
    is it possible to automatically mirror a file from another server on my own?
    Is that the kind of thing Cron jobs can do? (Only needs to run daily, 12hr-ly to be safe.)
    I'd also like to transform the (XML) file at some point (got the XSLT already) and was wondering if that could be done at the same time. (not a major problem if not)
    TIA, j
  2. ST8
    ST8 What's a Dremel?
    14 Feb 2003
    Which os are you running? IF nix check out rsync in conjunction with cron, if windows its prolly easier to use something like xcopy and a scheduled task. There is a windows port of rsync but it aint fast :)
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    it's linux, but not my server - is my hosting with www.prokmu.com
    (I guess I should ask them, but I'm not confident they'll know themselves tbh)
  4. jezmck
    jezmck Minimodder
    25 Sep 2003
    any other thoughts anyone?
  5. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    hmm i made a script ages ago which tracked players on NS servers (tracked just our clan + friends + the guy know as confidence), now the box that was running the website had cpanel, and through that i made cron run a PHP script every 5 minuites :D
    Now while i checked with the hosting people if that was okay (because it wouldn't of come out of my mates bandwidth, the way they log bandwidth) i had access to do that just on a regular cpanel account. How about that?
  6. jezmck
    jezmck Minimodder
    25 Sep 2003
    yeah, definately!
    sounds like what I need.
    I currently know nothing of cron, so if you can tell me how to use that too I'd be extremely grateful. (I can of course see how to select frequency etc, but don't know how the command to run should be entered)
  7. TheAnimus
    TheAnimus Banned
    25 Dec 2003
    well cron and howto in google work quite well.
    (tbh linux admin = google("%i HOWTO");)
    In short you have cron tabs. Tasks. Cron is a periodic task shecdualar. So you will just do the command /usr/sbin/php ~/script.php
    where the first one is the path to the php binary, and the second param the script your going to run with it. Simple eh?
  8. jezmck
    jezmck Minimodder
    25 Sep 2003
    lol, fair point.
    i've not used *nix beyond a couple of crap lectures a coupla years ago, so wasn't sure if there'd be more to it.
    I still need help with the file copying though.
  9. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    I used a program earlier this year for a few months to transfer files at certain times, with plenty of options - program is vice versa pro, dang, google's down again! Google it and you should find it. Its a 30 day trial version, but I got my copy from my school!
  10. jezmck
    jezmck Minimodder
    25 Sep 2003
    that's not what I need - I need it for work, and it must run from the server so it doesn't matter if I'm in transit.
  11. MrWillyWonka
    25 Jul 2004
    You can run the program from the server, you can also run it from the client if you want to.
