Windows automatic logon
Discussion in 'Software' started by Ben, 1 May 2004.
  1. Ben
    Ben What's a Dremel?
    11 Aug 2003
    Can some one tell me how to dissable the automatic login, in xp pro. I just want it to go to the welcombe screen, with the list of users.
    Ben
  2. SJH
    SJH Minimodder
    24 Dec 2003
    Go to the Control Panel, select "User Accounts" and then click "Change the way users log on or off".
    The options you'll need should be there :)
    -Sam
  3. Ben
    11 Aug 2003
    That does not work it still automatically logs me on.
  4. batsman
    batsman the quiet one
    14 Nov 2001
    you've not used tweak ui in the past to setup auto login have you?
    also mayb etake a look in your "local security setting"
    in administrative tools
    that has a whole host of options
  5. Ben
    11 Aug 2003
    no i have not used tweak ui.
    and i can not see any think in the local security setting thing. That i would change this.
    i have managed to do this befor there is a setting somewere i just can not find it.
    Ben
  6. zhenboy
    zhenboy What's a Dremel?
    23 Dec 2003
    Actually once u set a password the logon screen will appear...need u 2 type a password to logon
  7. Ben
    11 Aug 2003
    tryed that did not work???
    ben
  8. Smiffy
    Smiffy What's a Dremel?
    5 May 2004
    Start>Run "control userpasswords2"
    You should see the options you need there, that's all I can think of...
  9. Ben
    11 Aug 2003
    that's the setting thanks.
    Welcome to Bit-tech :)
    Ben
