Electronics Automotive tachometer
Discussion in 'Modding' started by K.Thiru, 10 Jun 2005.
  1. K.Thiru
    K.Thiru What's a Dremel?
    10 Jun 2005
    Hi, is there anyone familiar with the " automotive timing light" which is used to check the rpm and dwell.
    Is it possible to convert the mechanical/analog one into a digital one and where can I source the high tension clamp for the spark plug cable.
    How to convert the strobe light to a super bright clear LED and the sensor for detecting the flywheel mark?
  2. theshadow27
    theshadow27 What's a Dremel?
    23 Sep 2004
    an LED will not flash bright or fast enugh for it to work... that is why they still make them the old fassion way.
    there are no mechanical parts in a timing light, just a big capacitor, 2 coils, some transistors and a xenon flashbulb
    i dont understand what the point of making a "digital" (i assume you mean solid state? the existing types are digital: the light is either on, or off) timing light would be, there would no advantage.
    the clamp is not high tension - it is an inductive pickup - it operates around 0.5v. you can make one by taking a split toroid and wraping 5 or 6 turns of wire around one half, and glueing both halves inside of a spring clamp. you can detect the pulse with a MOSFET... (just like they have been using since 1970)
  3. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    You are half right, a LED is fast enough, but it would require a shitload of LED's or a 3-5W Luxeon to get usable light output, and you would still not get close to a xenon tube.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
  5. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    you can also push a LOT more current through the LEDs for a REALLY short period of time.
    Stuff like TV remotes push about 200 - 300 mA through the IR led, albeit for a period of less than a millisecond or two.
  6. theshadow27
    23 Sep 2004
    right - and a 5 watt luxeon pulsed at 50 watts would still take 100ms to reach full brightness, and another 100ms to die out - when you are looking at .1 degrees of timing this can be a problem
    a xenon flashbulb looks so much brighter because it is discharging all of its energy in .5 or so ms.
  7. g0th
    g0th What's a Dremel?
    12 Apr 2005
    Are you sure? Of course an incandescent light will take time to reach full brightness and die out, but i thought LED's had no such delay. Are such properties mentioned in Lumiled's datasheets?
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I don't know about Luxeons in particular, but standard leds have very low latency, or they wouldn't work in HF signalling applications.
    And you could dig up a HP patent,
    Now that's fast.
  9. K.Thiru
    10 Jun 2005
    I understand the point you had derived but the the probelm back here is the avaiability of the toroidal core and the swg of the pickup coil and also the clamp. And also the calculations leading to the coil design which is not avaiable. If you show the calculations and the source for the parts I would be grateful.
  10. K.Thiru
    10 Jun 2005
    Thank for your feedback as I also had the skeptical notions about using the LEDs but going thru' the silicon chip " automotive LED timing light" it is possible but I have to test it on loclly produced cars for confirmation.By the way the LEDs mentioned is of "super bright clear".
