Windows AVG Antivirus keeps popping up?
Discussion in 'Software' started by bishvabis, 18 Nov 2011.
  1. bishvabis
    bishvabis What's a Dremel?
    18 Nov 2011
    Almost everyday when I get on my computer a windows box comes up and says that the antivirus hasn't passed their security or something and it says continue with installation anyways or stop installation. It pops up at least five times after you click on your selection, then eventually the AVG antivirus box will come up and say I need to restart. Any help is appreciated, thanks!
  2. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    uninstall avg, restart and reinstall avg
  3. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    uninstall AVG. install microsoft security essentials.
    seriously. AVG has gotten bad with their annoying crap. they used to be good, not so much anymore.
  4. Jor1995dan
    Jor1995dan Minimodder
    6 Feb 2011
    This. I was using AVG, then went to MSE upon recommendation from one of my college lecturers, and will not go back. MSE is so much better!
  5. AstralWanderer
    AstralWanderer What's a Dremel?
    17 Apr 2009
    Don't install MSE - there are better free options out there. Notably Avira which, at 99.5% was one of the best performers in AV Comparatives' most recent (PDF) comparative tests. MSE in comparison scored third from bottom with 92.1%.
    MSE was also rated poorly by Virus Bulletin (scoring ~80%/65% on their Reactive/Proactive chart - Avira getting ~95%/85% in comparison) and AV-Test (who gave MSE a 2.5 out of 6 protection score compared to 4.0 out of 6 for Avira).
  6. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    MSE does what I want leaves me the f**k alone to enjoy my computer, otherwise what's the point!!
    Edit: AhhhhhhhhhhhGGGGGGGGGGGGGG my avatar what have you done, that's just evil!!
  7. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    I'd go Avast in gaming mode. :thumb:
  8. happysack
    happysack goodateverthinger
    19 Dec 2009
    Get MSE
  9. DK63
    DK63 Resident magpie
    8 Sep 2009
    Get the one you are most comfortable with. I've used both AVG and MSE. Neither is perfect, seen infections on pc's with both. I use MSE because I got fed up with the advert banners on AVG.
  10. DK63
    8 Sep 2009
    update: got rid of MSE as pc got infected, had to reinstall. Now using paid version of Bit Defender Internet Security 2012.
  11. Andersen
    Andersen Brain for hire
    25 Nov 2002
    This is why MSE is such a good buddy/AV. I can keep on gaming when a scan is going on in the background. Also it comes in offline version which is pretty great and rides on my USB stick toolkit.
  12. AstralWanderer
    17 Apr 2009
    Conversely, what's the point in running an AV that doesn't detect malware adequately, leading to your computer being compromised?
    Performance should be one factor, but by no means the only one - and the most thorough scanners will need to spend more time examining each file due to the many methods available to disguise malware (file compression or packing, encryption, code morphing, etc).
  13. rickythomas
    rickythomas What's a Dremel?
    27 Mar 2012
    AVG is creating for the users these days, i dont use it on my PC, i am using eset since a year.
  14. Zago
    Zago What's a Dremel?
    22 Jan 2012
    I have also switched from AVG to MSE for similar reasons, personally really like MSE - easy to use, doesn't constantly bother me but does remind me to do a full scan each week!
  15. Sexton
    Sexton Minimodder
    2 Jun 2010
    Uninstall AVG. Install Avast.
    Easy.
