Windows AVI Divx to DVD?
Discussion in 'Software' started by Malvolio, 10 Jul 2005.
  1. Malvolio
    Malvolio .
    14 Dec 2003
    With the addition of a dvd burner drive, I would like to convert some of my divx encoded home movies and TV shows onto a dvd.
    I'm told that nero will create a good quality disk, but that it can't be played in a pc, and the only dvd player I have is my pc. So thats kinda useless.
    "AVI DivX to DVD Converter" seems to be working, but I have a feeling that it will do the same thing as nero, which would suck as I don't realy have a need for another coaster (I've already got a nice collection care of AOL).
    So I need software that will allow me to put movie files (DivX encoded) onto a standard dvd-r.
    As well, would it work if I just burnt the files directly onto a dvd in their existing format? I've attempted this with cd-r's with no success; the movies just freeze 5 minutes after they begin.
    Any and all help would be muchly appreciated! I'm new to this whole dvd burning thing.
    By the way, if it helps, I've got a LiteOn 16X DL dvd burner and am using Sony 8x dvd-r.
  2. dfhaii
    dfhaii internets
    24 Mar 2002
    You can't just burn the divx to disc as it is mpeg4 and dvd video is mpeg2 thus it wont play, however I haven't converted mpeg4 to mpeg 2 so I am unable to reccomend any software/give advice.
  3. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
  4. Malvolio
    Malvolio .
    14 Dec 2003
    As I explained in my original post I'm unable to do that as I've been told by a few friends that the disks won't be able to be played in a computer, and this is necessary.
    Anyway, I just went ahead and burnt the files onto the dvd without the whole movie format BS stuff. Works perfectly, and plays on the computer it's ment for.
  5. Awoken
    3 Mar 2004
    Erm, I put some TV episodes I had onto DVD using nerovision, it worked fine on the PC, just like a normal DVD.
  6. Kevo
    Kevo 426F6C6C6F636B7300
    9 Sep 2001
    SVCD 2 DVD can do it...
  7. Malvolio
    Malvolio .
    14 Dec 2003
    Thats strange :eyebrow: I even got ahold of a disk that was burnt using nero, and out of three dvd drives, none of them will even pick up the disk (liteon and MSI on my main rig, and toshiba on my laptop).
    Guess it just depends upon method/media?
  8. Awoken
    3 Mar 2004
    Could be media dependant but as you can read the media when you write in a different format I'd say no. Have you tried using a more up-to-date version of nerovision?
  9. zjmedia
    zjmedia What's a Dremel?
    14 May 2004
    WinAVI Video Converter can easily do this trick perfectly! And you can find it from http://www.winavi.com/avi-to-dvd.htm .
    Maybe you can download one to have a try! Anyway, it is free to try!
  10. Atomic
    Atomic Gerwaff
    6 May 2002
  11. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    DVD Santa is another that will convert avi(divx) to DVD(vob).
