Other AVI playback issue
Discussion in 'Software' started by mike.sufc, 24 Mar 2009.
  1. mike.sufc
    mike.sufc What's a Dremel?
    9 Feb 2007
    Hey there, this isn't an issue which is gonna kill me but it sure as hell bugs me!
    When I playback any .avi file, the very top and very bottom scan lines are mixed up throughout playback. This happens in vlc AND Mediaplayer classic.
    I dunno if this helps visualise it, but the lines appear in this order
    6
    5
    Does anybody know what might be causing this???
  2. Krikkit
    21 Jan 2003
    Does it do it in all players? Have you tried changing codecs?
  3. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    VLC uses it's own codecs, MPC uses directshow codecs, so it's probably not a codec thing.
    it's a very wierd issue, i can't say i've ever heard of it before. could be a drivers thing, i suppose. and you're sure it's every avi, not just a few? avi is just a container, not an compression format, it usually contains video compressed with either XviD or DivX. try finding a file you know is XviD and one you know is DivX and ensure it happens in both of those.
  4. mike.sufc
    9 Feb 2007
    Hey thanks for the responses. I have checked the avis out in gspot, and found a couple of Divx and a couple of Xvids, and they both have this problem! I tried them in VLC and MPC as well!! How strange...As you say, it must be a driver thing then.
    I have a 3850pro and will try updating my drivers tomorrow.
