Windows AVI to VOB converter needed
Discussion in 'Software' started by adam_bagpuss, 20 Apr 2010.
  1. adam_bagpuss
    24 Apr 2009
    good evening people,
    i find myself in a bit of a fix. ive got some .AVIs i need to convert to .Vob as i have moved my main gaming PC well away from my TV which i used to have hooked up via DVI.
    tried a google search before any answers so.. like type AVI to VOB in google and a million hits came up lol. seen quite a few of those replies of late.
    i shifted through the crap until i found FACV, which look like it was for me. however it crashes at 98% so that was epic fail.
    others i looked arent free which i forgot to mention is a must as i dont need to do this all the time so dont really wanna waste the cash.
    does anyone know of a decent converter thats free and does a good job ?
    thanks in advance
  2. adam_bagpuss
    24 Apr 2009
    thinking about it, can the PS3 play AVI files ?
    never tried but a quick google search says yes but depends on codecs, however not sure how to play them on PS3 as its not mine so i never use it.
  3. adam_bagpuss
    24 Apr 2009
    ended up using DVD movie maker seems to work ok.
    still interested in the PS3 playing AVIs though if anyone knows ?
  4. geoboy333
    geoboy333 Sometimes I say something bright...
    28 Sep 2009
    i have a great little avi to vob converter. its called DVDflick and its the best all in one DVD authoring software i have come across. You can convert straight to a disk or you can just tell it to convert and put it in a folder. Go with DVDflick my friend you will not be dissapointed.
  5. adam_bagpuss
    24 Apr 2009
    how longs the encoding ?
    i used windows movie maker last night and jesus its slow.
    i have a 4Ghz i7 920 and it took about 30-45mins give or take as i wasnt watching to encode and burn
