TVs Awful picture on HDMI
Discussion in 'Hardware' started by Harlequin, 15 Aug 2012.
  1. Harlequin
    Harlequin Well-Known Member
    4 Jun 2004
    the childrens tv isnt well i think - when using HDMI the colours are aweful , with hazing everywhere , in games , on sky - everything - , yet , when using scart or component from the xbox its perfectly fine
    any idea`s?
  2. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    Have you tried a different HDMI cable? It may be a fault with the cable itself. Once you've ruled that out we can try and determine what the issue is exactly.
  3. Harlequin
    4 Jun 2004
    3 different cables in both ports and its the same :(
  4. yassarikhan786
    10 Aug 2011
    Have you gone through the settings on the T.V to try and resolve the issue?
  5. TheStockBroker
    TheStockBroker Well-Known Member
    19 Nov 2009
    Xbox/Xbox 360?
    If the latter, what's the output resolution set at? - It needs to be a setting your TV displays natively, not just supports. Also, you can change the colour types in the 360 settings if needed.
  6. Harlequin
    4 Jun 2004
    ok the xbox is set to output 720p , teh res of the screen (also does the same in 1080i) , changed all settings but its still there , a coloured `haze` around everything
  7. Harlequin
    4 Jun 2004
    its a samsung 26" btw
  8. Shirty
    Shirty Time travelling rogue Super Moderator
    18 Apr 1982
    Bit back to front, but do you have any friends with an xbox you could borrow for 5 minutes just to check that it's not the source of your woes?
  9. yassarikhan786
    10 Aug 2011
    He said in the OP it happens with his Sky Box as well, so I don't think it's an issue with the Xbox. Then again it could be :/
  10. rollo
    rollo Well-Known Member
    16 May 2008
    Most likely that hdmi port is broken which is a replacement telly job as I'm not sure they are repairable.
    You have tested other items like sky and it's still the same and you have ruled out cables so it's nigh on certain to be the tv.
  11. TheStockBroker
    19 Nov 2009
    Oh wait, is it your independent Sky Box too? I read it as as Sky on the 360..?
  12. yassarikhan786
    10 Aug 2011
    Ah, I don't have an Xbox so wasn't aware that you could stream Sky through Xbox Live?
  13. Shirty
    18 Apr 1982
    :duh:
    I didn't :read: properly did I?
  14. Harlequin
    4 Jun 2004
    it happens on a sky hd box + an xbox 360 (and yes they do watch sky on teh xbox as well) , component it is then as the hdmi ports are knackered?
  15. yassarikhan786
    10 Aug 2011
    Yeah it looks like the ports are knackered :(
  16. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    You could get it fixed/engineers report, but the cost would be close to the price of a new TV if you went through a Samsung dealer.
    Sent on my CM10 JB powered i9100 by TapaTalk 2
  17. Showerhead
    Showerhead New Member
    11 Jan 2010
    Give this a go. I've a weird issue with my monitor where using one of the DVI connections causes the displayed image to be way brighter for some reason.
