Case Mod - In Progress AzTtec - Added Keyboard and Mouse - Completed!
Discussion in 'Project Logs' started by dmcgrath, 1 Sep 2011.
  1. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    It maybe do not die, but you'll have to be very careful to don't do splinters on your case..
    It doesn't exist a kind of glaze to harden it?
    Anyway, you're doind a precise and fantastic job!!!
    Good luck! :thumb:
    dmcgrath likes this.
  2. dmcgrath
    dmcgrath Master of Pancakes
    14 Aug 2011
    I'm looking into the water runoff damage thing. But for the most part, the stuff I showed where it might be needed, has almost disappeared.
    On to the good stuff - another major update.
    Here is a few happy detail shots of the successful drybrushing effect I'm getting.
    I also decided last night that I no longer liked the lock cover on the door. It was a sliding piece, and it never really sat well with me. SO I redesigned it to be exactly like the one in the front. Piece of cake.
    Here's the easy way to use that moss stuff, in case you ever want to use it yourself. I used a small paintbrush to apply some simple PVA/Elmer's type glue.
    Then pack the foam into the area, don't be shy, you can press it into place or just sprinkle it on, if your project is laying relatively flat.
    Then just wait, and use a larger bristled brush to remove the excess, into a bag/container for reuse.
    I then wanted to make some vines. This was problematic, I tried using paper, yarn, string, glue, and a couple other idea. They all kinda failed for one reason or another.
    Then I tried to use hot glue.
    This seemed like a good idea.
    I tried making some onto foil, but they stuck to the foil. Then I tried wax paper... stuck to the paper, then the glass tray from my microwave. They stuck too well to that also.
    I ended up drawing vines directly onto the places where I wanted them.
    And painted it to see if I was headed in the right direction.
    Happily, I believe I was.
    I needed leaves, for the vines to look somewhat less crappy.
    So I made some out of Super Sculpey, then hot glued them down and painted them.
    I also needed to do the other side door fan. I think this turned out really well so far.
    **DESIGN MOD TIP***
    As another idea. This stuff (hot glue) is pretty neat as a design material. I wanted to make a mod with veins on the outside of it someday. (Veins, just vines without leaves). The clear sticks of glue I'm using really scatter light well also. They would look pretty amazing lit up.
    And some leaves added.
    And base coat. Time to let it dry.
    Ladies and gentlemen, there is light at the end of my tunnel! This mod is almost done I think!
    RedManc and Waynio like this.
  3. matiss
    matiss Minimodder
    24 Jun 2010
    *drops down dead by pure shock of awesomeness of this mod*
  4. ArchType
    ArchType What's a Dremel?
    9 Oct 2011
    Duuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuude... How can one case be so awesome???
  5. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    If I may I'd like to ask you something :
    How much would you charge me to build a 1:1 scale aztec temple, so that I could live in it ? :D
    Very nice job, very nice job, very nice job (have to say it three times)
  6. Atasimey
    Atasimey What's a Dremel?
    19 Oct 2011
    What about the hot glue veins and sneakily embedded led lights - could work gently sanded like sanded acrylic for glow? God if I weren't in the process of moving houses I would run off to spill my glue right now.
  7. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    now what you going to do ...during the long winternights .. lol..
    excellent job
  8. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    this is insanE!!
    The vines look great I think this is the best finish you could have asked for if all the other attempts failed!
    can't wait to see the last shots :D
  9. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    damn :O, im speachless!
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    Really glad I stumbled into this log :) sweet sweet sculpting, over how long did this take you to do?.
    +rep
  11. O_Pucaro
    O_Pucaro What's a Dremel?
    7 Mar 2011
    i´m in love
  12. Watchtown
    Watchtown What's a Dremel?
    2 Mar 2010
    Thats gorgeous! love the details:thumb:
  13. dmcgrath
    14 Aug 2011
    Thanks Waynio, I've spent the better part of 60 days doing this. Working on it nearly every day. But I never clocked myself. (The Aztec calendar carving alone I know took 70+ hours though). Probably nearing 250 hours I imagine, from planning to finish.
    Haha, thanks Atasimey. I had that thought, I was thinking about something that makes a heart beat noise, and to time flashing pulses of LED's to illuminate it. (And so much much more that is beyond my technical know how for now)
    Thank you, Blarte! I'm sure I can find other things to keep me busy, but San Francisco doesn't get much in the way of long nights with bad weather
    Thank you sir, I am humbled. I am going to have a hard day when I have to ship it back to Thermaltake for sure. As for making a full size temple, it's probably too costly. How about just a dog house, or a bunk-bed setup? :dremel:
    I'll do a bit more touch up to the case, and then on a decent weather day here, I'll take a bunch of final pics and then that should do it.
    Thanks again everyone!
  14. dmcgrath
    14 Aug 2011
    Okay, well, I think it's officially done.
    A few parting shots. In the best light I had available.
    And I started to pre-pack the thing in it's original box. Of course there was a casualty.
    Thankfully the stuff is easy to re-glue and it leaves no visible seam.
    That is two errant finger nails. So it needs paint touch up. sigh...
    Then the actual fitment and packing, I sawed and filed a TON of the original packing foam to fit.
    But, the front needs to be shipped separately. It's rubbing in the box and I can't take the chance.
    The top was just as messy, but not so bad placement wise. The Quetzalcoatl is wider and taller than the original handle so I had to split the foam to accommodate it.
    Well, that is just about it for this thread. It's time for me to get to work on my daughter's Halloween costume, and pumpkins, and window decorations, and looking for a job. Etc.
    Thanks for looking!
    _dan mcgrath
    FiXeL, awadon and IanW like this.
  15. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    I'm an atheist. But I'm going to pray for this amazing masterpiece to arrive at TT in one piece! :thumb:
    Oh, and thanks for showing us that no matter how much time we spend on modding, there is someone out there who makes us feel we have a life :lol:
  16. awadon
    awadon What's a Dremel?
    23 Jan 2010
    I don't know what to say. F@cking good job !!
    stars+rep
  17. westham101
    westham101 MWN Gamer
    13 Jul 2010
    Wow!! Nice work.. Im extremely jealous!
  18. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    That's freaking amazing work. I hope the fragile foam gets there safely.
  19. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    beautiful piece of carving. whish i could have such skill or patience...
  20. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Absolutely sensational build dude. Congratulations. :thumb:
