News Azza announces pyramid-shaped mini-ATX case: Pyramid Mini 806
Discussion in 'Article Discussion' started by bit-tech, 4 Aug 2020.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. BeauchN
    BeauchN Multimodder
    5 Apr 2011
    Mini-ATX or Micro-ATX?
  3. enbydee
    enbydee Minimodder
    10 Jul 2014
    Mini-ITX
  4. wolfticket
    19 Apr 2008
    ...A pyramid shaped case... Because I have just too much desk space :happy:
  5. adidan
    25 Mar 2009
    I always intended to make a pyramid case, thought it'd be good for getting heat out of the top without fighting the natural rising of the hot air.
    But yeah, i'm lazy, it never happened.
    Interesting to see how it works out on the cooling front.
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    For the CPU or the GPU?
    The cpu will be fine (provided you spend half of your remaining lifespan removing dust from the cou cooler) as there are generous openings on both the bottom and top.
    The gpu on the other hand is sandwiched between the bottom and mobo tray... worse yet, if you dig through the pictures on the Azza website you can see that the air intake for the GPU looks very restrictive:
    http://www.azzatek.com/m/2010-1275-364381.php?Lang=en
    adidan likes this.
  7. adidan
    25 Mar 2009
    :eeek:
    Hello Mr Drawing Board, nice to see you again.
    The_Crapman likes this.
  8. David
    7 Apr 2009
    Still looks like a 3D printer to me
  9. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Great for toblerone fans I suppose
Tags: Add Tags
